Is this possible?
Old Jul 24, 2008 | 02:02 AM
91civicsikid's Avatar
Default Is this possible? (pics)
Can I connect an a/c switch into the wire containing the clutch engagement sensor?
Modified by 91civicsikid at 4:24 AM 7/26/2008
Modified by 91civicsikid at 4:25 AM 7/26/2008
Old Jul 25, 2008 | 10:49 AM
dth0ng69's Avatar
Default Re: Is this possible? (91civicsikid)
a wise honda-tech member once had on his signiture
"nothing is impossible it just requires more time and money"
Old Jul 25, 2008 | 11:08 AM
fcm's Avatar
fcm
Old Fart
Not sure I understand what it is you want to do, by "clutch sensor" do you mean "Clutch Interlock Switch" and are you trying to bypass it, use the A/C switch as a kill switch? 94
BTW dth0ng69 the quote is "Nothing is impossible, the impossible takes longer and costs more money"
Modified by fcm at 5:47 AM 7/26/2008
Old Jul 26, 2008 | 02:46 AM
My apologies for the vagueness. A first read my post again before even reading your responses and realized how vague it was. But anyway..
I made a diagram.. just 'cause i got bored.. so here you go.
And I guess the better question now is not is.. but how.. is this possible?
Old Jul 26, 2008 | 02:53 AM
Default Re: (91civicsikid)
And if you know anything about electricity you will notice there is no load.. .well the diagram isn't 100 percent. I just drew it for myself. Here is the real diagram (minuce the switch, obviously) I hope this helps.
http://i142.photobucket.com/al...m.gif
Old Jul 26, 2008 | 05:20 AM
fcm's Avatar
fcm
Old Fart
Well I guess I am going to have to assume you want it as a "kill" switch as you still have not said what you want the switch for.
The CIS, [clutch switch] supplies the starter relays coil with a ground, [blue/black] the other side of coil gets power from the ign. switch, [black/white] so if you want to use the A/C switch as a kill switch all you need to do is disconnect the CISs input, [black] from ground and connect it to the output of the A/C switch, which should be a ground, [to A/C pressure switch] depending on MM&Y of car.
You may also need to rewire the input to the A/C switch to a chassis ground or you will also need to turn on the heat/A/C blower switch, [any speed], as that is where the A/C switch gets it's ground. 94
Old Jul 26, 2008 | 12:36 PM
Default Re: (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Well I guess I am going to have to assume you want it as a "kill" switch as you still have not said what you want the switch for.
You may also need to rewire the input to the A/C switch to a chassis ground or you will also need to turn on the heat/A/C blower switch, [any speed], as that is where the A/C switch gets it's ground. 94</TD></TR></TABLE>
There are a couple of problems with that. I don't have air conditioning. It is an si. What is weird though is there is still a place for the switch to plug in as it is plugged in right now. What is weird is the dash light on it works when i turn on my headlights but the smaller light does not turn on when I flip the switch on and off.
I guess my main question in all of this is what guage wire am i dealing with and where is it easiest to get to. And how much wire will I need.
As rediculous as this may sound, I also plan on doing a fuel kill as in the one on here somewhere and tucking the switch by my back seat. Overkill? maybe but I plan on using the "clutch one" just whenever and the fuel one when it's going to be sitting awhile.
Old Jul 26, 2008 | 02:31 PM
fcm's Avatar
fcm
Old Fart
If the A/C switch is plugged in the illumination light will work.
Have you tried turning on the blower, [any speed] and then seeing if the A/C indicator light comes on?
There should be 5 wires/terminals in the A/C switch plug, colors may be...
1- Green, illumination bulb ground, from "Dash Light Brightness Controller", may also be red.
2- Light green, illumination bulb power, from head light switch, [park light circuit] may also be red/black.
3- Black, ground input, from blower switch, [any speed] may also be green.
4- White, A/C switch output, [ground out when switch is on] to A/C pressure switch, [if you had A/C] may also be blue/red.
5- Blue, power for A/C indicator bulb, [hot when ign. is on] may also be black/yellow, ground for the bulb is internal when A/C switch is on.
Remember for the a/C indicator light to be on the ign. switch must be on, the blower motor switch must be on, [any speed] and the A/C switch must be on. 94
Old Jul 26, 2008 | 11:20 PM
Default Re: (fcm)
Good Call. The light turned on when i turned on the blower.
That is good and bad. It throws something else into the mix but I think I have it figured out.
By looking at this diagram, the blower prevides it with ground, not power. Meaning, O could not use that ground, or my car would not start without the air on, correct?
So what i need to do (correct me, if I'm wrong) is
<U>off a/c switch</U>
Green Wire to Ground (possibly to red wire, depending on if switch is before or after light)
Red Wire and Black/red are good
Black/Yellow is good (blower switch provides ground, not power)
Blue/Red wire to provide the clutch interlock switch with a ground.
Good?
If not, tell me why
If so, tell me how to find this ground after the CIS. Everything else is basically good.
Old Jul 27, 2008 | 06:10 AM
fcm's Avatar
fcm
Old Fart
As I said, all you need to do is use the output from A/C switch, [blue/red] connect it to the input, [black] of the CIS, [cut black lead and connect the blue/red lead to the CIS end of cut black lead.
You will now have to turn on the blower, turn on the A/C switch and step on clutch for car to start, the blower and A/C switch have to be on only when cranking to start, once engine is running the blower and A/C switch can be turned off or left on, it makes no diff. 94
Old Jul 27, 2008 | 08:48 AM
Default Re: (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">As I said, all you need to do is use the output from A/C switch, [blue/red] connect it to the input, [black] of the CIS, [cut black lead and connect the blue/red lead to the CIS end of cut black lead.
You will now have to turn on the blower, turn on the A/C switch and step on clutch for car to start, the blower and A/C switch have to be on only when cranking to start, once engine is running the blower and A/C switch can be turned off or left on, it makes no diff. 94 </TD></TR></TABLE>
well i planned on just splicing the green wire and connecting it to a ground, therefore bypassing the blower switch. Having to turn the blower on to start the car is a bit much. Well I think I am good. All I need to know is where to locate the CIS
Old Jul 27, 2008 | 09:55 AM
fcm's Avatar
fcm
Old Fart
The CIS is mounted high up on the clutch lever.
Every layer is a good layer, but easy enough to ground the green lead going to A/C switch. 94
Old Jul 27, 2008 | 01:32 PM
Default Re: (fcm)
where would it be easiest to splice that ground and connect it to the switch?
Old Jul 27, 2008 | 04:46 PM
fcm's Avatar
fcm
Old Fart
How **** do you want to be?
The best would be the depin the black lead from the CLS plug, "open" the metal terminal up, [unfold crimp] and remove the black lead, tuck it away, no need to cap it, now re-crimp, [and solder] a black lead of the same or larger gauge and long enough to reach the A/C switch, re-pin it into the CIS plug, route the lead neatly to the A/C switch and do the same thing there, only with the green wire/terminal at the A/C switch plug. 94
Old Jul 27, 2008 | 09:04 PM
Default Re: (fcm)
alrighty. I'll update you once I start it. I'm going away for awhile So it will be awhile but I will let you know. Thanks for the help.
Old Aug 6, 2008 | 11:03 AM
So I tried messing with this today and realized the clutch interlock switch is pretty much impossible to get to. Do you have a better alternative. It pretty much has to be in that circuit being that I want it to only be affective to anything when starting the car.
Old Aug 6, 2008 | 05:07 PM
fcm's Avatar
fcm
Old Fart
Not if you what to use the ground out of the A/C switch to supply the CIS, however you could go the the starter relay, disconnect the input lead from the CIS, run it to the A/C switch and connect it to the input, [green], [the one you would have grounded so you would not have needed to turn on the blower switch] then run a lead from the output of the A/C switch, [blue/red] back the the starter relay and connect it to where you disconnected the lead from the CIS.
The CIS will provide the A/C switch with a ground, [instead of the blower switch supplying the ground] then the A/C switch will supply the starter relay with a ground, [when on]. 94
Old Aug 15, 2008 | 02:50 AM
Hey. I got my hand on the CIS and traced the wires to where I could get to them and finished the project. It works great! Thanks for the help.
josh352727
Aug 19, 2011 08:54 AM
mattbatson
Oct 3, 2010 03:40 PM
Civic138
Feb 11, 2006 10:42 PM
V-SPEC 1
Dec 24, 2003 11:23 PM
