Problem with AU94TM
Old Jul 7, 2008 | 09:58 PM
sgT's Avatar
sgT
Default Problem with AU94TM
Hey guys,
I just installed a viper alarm with this au94tm. The outer proximity range seems to be working fine, but the inner range refuses to trip unless I hold the sensor in my hand. Currently I have it sitting out under the e-brake with the center console out and even with the sensitivity turned all the way up it won't trip without the situation mentioned above. Is it possible that I got a defective one?
Old Jul 7, 2008 | 10:26 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: Problem with AU94TM (sgT)
does, it work if its not covered up
Old Jul 8, 2008 | 04:28 AM
fcm's Avatar
fcm
Old Fart
If adjusting it changes the outside zone but has no effect on the inside zone then it is either a defective sensor or it is a wiring issue. 94
Old Jul 8, 2008 | 06:11 AM
sgT's Avatar
sgT
Default Re: Problem with AU94TM (fcm)
wrx: its not covered up and theres no interior in the car. Just sitting on top of the carpet
fcm: Yeah, I was thinking the same thing...
Do you guys see a lot of these bad out of the box?
Old Jul 8, 2008 | 11:05 AM
fcm's Avatar
fcm
Old Fart
I have seen maybe 1 or 2, [out of 100s]that were bad, in most cases it is a wiring issue.
So the question is how is it wired to the alarm?
What is the make and model of the alarm? 94
Old Jul 8, 2008 | 05:32 PM
sgT's Avatar
sgT
Alarm = Viper 1002
Wired to the option port
I dont think its a wiring issue, heres my logic:
Sensor turns on, so power and ground are good.
when the red and green lights come on, the alarm does trigger
Green light comes on and I see changes in sensitivity when I adjust it.
Red light does come on, but does not change with adjustment.
What do you think?
Old Jul 8, 2008 | 06:07 PM
fcm's Avatar
fcm
Old Fart
Sensor is defective. 94
Xxcivic99xX
Audio / Security / Video
Mar 7, 2008 04:28 PM
Pat McGroin
Mar 2, 2007 11:26 AM
H9Omega
Oct 10, 2006 03:35 PM
TypeRod
27
Nov 3, 2005 08:19 PM
Full Race A6
May 24, 2004 05:44 PM
