Classic Hondas All Pre-1988 Hondas.
Compression Test Results
Old Jun 23, 2008 | 07:39 AM
jason1781's Avatar
Default Compression Test Results
My 86 CRX HF has lots of white smoke in the exhaust @3000+ rpm. I ran a compression test and here are my results.
Dry:
#1 - 210
#2 - 215
#3 - 215
#4 - 218
Wet:
#1 - 215
#2 - 220
#3 - 215
#4 - 222
Anyone have any ideas of what the problem may be?
Old Jun 24, 2008 | 12:48 AM
NW Classic Honda's Avatar
Default Re: Compression Test Results (jason1781)
Your compression looks fine...
Old Jun 24, 2008 | 04:55 AM
ex1z7's Avatar
white smoke is coolant, no?
Old Jun 25, 2008 | 11:07 AM
fitfreak3's Avatar
Default Re: (ex1z7)
I thought white smoke means that you are running lean. You are not getting enough gas to the carb or possibly your injectors may be clogged? Check your plugs and see what they look like. If I remember correctly black sooty plugs mean you are running rich and brown means you are running lean
95greenlude
Nov 3, 2007 04:21 PM
TekSI
Oct 12, 2005 05:14 PM
RCautoworks
Sep 1, 2005 11:16 PM
EK9 BEEZLER
Apr 21, 2005 09:26 AM
SIK IN DA HED
Apr 25, 2003 06:16 AM
