87 crx si problems!!
wat up guys here are my issues i have an 87 crx si recently swapped a b series motor well now my brake light fuse and my starter fuse keep popping as soon as i connect the battery. I checked all the wiring to make sure nothings grounding out were its not suppose to. Does anyone have any ideas of what might be causing this problem?? any input very appreciated ive been dealing with this problem for a while
Also does anyone know how to lower the front of these cars ???
And does anyone know if any aftermarket traction control bars are available for this year crx???
Re: 87 crx si problems!! (olskoolrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by olskoolrex »</TD></TR><TR><TD CLASS="quote"> And does anyone know if any aftermarket traction control bars are available for this year crx??? </TD></TR></TABLE>
Nothing (or close to noting) is available in the aftermarket for these old cars.
go over to http://www.redpepperracing.com, the best forum for these old cars.
Scott
Scott
In a Junkyard near you.
You obviously have a wiring issue. Are you using the stock fuse box and ignition switch?
Need to know how you did the swap before we can really help..
yes im using the stock fuse box and ignition switch. My engine harness was done by hasport and Zdyne so everything was pretty much plug in besides the pinning of the ecu
Exit Music
12-11-2005 08:55 AM
