87 civic SI idle problems
Well just picked up a 87 civic si for my daily and it wont hold a idle when it is cold untill it is warmed up then it will jump a little bit could it be the iacv? and it is also very slugish bad injecter possibly let me no what you guys think thanks in advance.
Re: 87 civic SI idle problems (BigHenault)
If the timing belt is old it is possible for it to slip a tooth, causing some similar problems. I would check cam and ignition timing as well.
A can of injector cleaner might help, other wise have them cleaned and balanced if you think it is an injector problem.
Scott
Scott
REDBARON
10-04-2001 07:40 PM
