Classic Hondas All Pre-1988 Hondas.
carb
Old Jul 25, 2008 | 06:44 AM
benms79's Avatar
Default carb
i have a 86 honda accord, the car idles fine untill it heats up then idles really high(4000 rpm) can any one give me some advise?? or does any one have a pic or diagram of the linjage setup? i believe this is were my problem is not sure, theres 2 swinging parts on side of carb,but not hooked together,is there suppose 2 be something connecting the two to work together( controls the plate inside of carb)?? if i had a diagram i would be able to kno if there is something missing.(spring or something)
Old Jul 25, 2008 | 07:00 AM
benms79's Avatar
Default Re: carb (benms79)
this is what im talking about if it helps any
Old Jul 30, 2008 | 07:30 PM
greentee76's Avatar
While I can not see the pictures that you posted, it sounds to me like you have a vacuum leak in the line that goes to your throttle controller(vacuum diaphram on passengerside front of carb). I know if you remove that line with the engine running the idle rises very quickly to the type of RPM's that you are talking about.
I hope this helps you. If you need more help I would suggest heading over to 3geez.com and searching for the problem you are having.
Good luck with it.
tgkaotic
Oct 3, 2012 09:21 PM
NickJones21
May 19, 2011 03:31 PM
PhilNLucky
Jul 31, 2005 01:36 AM
adamjenkins80
Apr 15, 2005 09:04 AM
honda8882
May 13, 2003 09:55 AM
