So this is where i'm at for lowering my wagon. Plz help
I've taken off the subframe and i have also taken out the torsion bars(not pictured). What do i have to do next to lower my suspension?
Re: So this is where i'm at for lowering my wagon. Plz help (eg831)
well, technically you should buy stiffer torsien bars. anyways, if you slide the t-bars out of the tubes, which you really didn't need to drop the subframe, they are splined like axles. all you have to do is rotate ONE SIDE OF THE TORSIEN BAR like 1-2 splines, then insert.
there are adjustment nuts on the torque tubes of the t-bars that you then use for "fine adjustment". but if you don't replace the t-bars with something stiffer from upgrademotoring.com, then the ride will suck.
Re: So this is where i'm at for lowering my wagon. Plz help (E-AT_me)
thanks for the help.
Yah i had to drop the subframe because the oil pan was in the way of the driver side t-bar. But Do u have to cut new splines? Sorry, but is a spline the gap like part on the threads? And which way do i move it over?
Sorry, but i'm really new to this whole torsion bar thing
you're talking about the "keyway". yes you have to grind a new one. not too hard with a dremel.
WKhbnrd
13
03-25-2013 02:55 AM
erasable180
03-27-2006 07:09 PM
