Classic Hondas All Pre-1988 Hondas.
1987 CRX HF carb to MPFI
Old Jun 24, 2008 | 12:06 PM
daddy's Avatar
Default 1987 CRX HF carb to MPFI
Ok i've done alot of searching and it seems most leads to broken links but i want to know what i need in order to convert an 87 CRX HF (carberated) to MPFI in preparation for B20.
I believe i can do this with an 87 Si harness? is that correct? also does anyone have a valid link for then converting the si harness from DPFI to MPFI
prolly should have put this in the pre 88 section. if a mod wnats to move it htat'd be good. thanks
Modified by daddy at 2:39 PM 6/24/2008
Old Jul 2, 2010 | 01:06 PM
c_larsen1208's Avatar
Default Re: 1987 CRX HF carb to MPFI
me too why hasnt anyone posted anything
Old Jul 2, 2010 | 05:42 PM
E-AT_me's Avatar
the Si harness is already MPFI. and you also will need a new fuel pump, computer, etc.
Old Jul 10, 2010 | 04:09 PM
allmotorRyan's Avatar
read his post he has a 87 HF not a si he wants to know if the si harness will work and yes it will
Old Jul 10, 2010 | 05:22 PM
E-AT_me's Avatar
i did read his post. did you? if you see above, i quoted what i answered..
Old Jul 27, 2010 | 09:53 AM
FMN716's Avatar
First off try get a donor car will work out much cheaper I am from South Africa so I am not sure it your shape came with fi already I think they did right
Anyways see these posts they are for prelude but will help for sure
* http://www.************.com/forums/s...d.php?t=232771
* http://www.************.com/forums/s...d.php?t=206797
Old Jul 28, 2010 | 07:07 AM
bgfshrcr's Avatar
IMO find an si car. They're pretty cheap. Even if you do that a lot of wiring changes have to be made. Swapping from obd0-obd1 isn't all that bad. In some respects the 87 isn't even obd0 so there's more involved. You would def need a harness, ecu, etc. Good luck!
hondaex99
Oct 29, 2009 09:19 PM
89loudcrxsi
Apr 7, 2008 11:25 AM
y-49
Sep 2, 2006 01:55 PM
CrxBoy6690
Apr 3, 2006 06:27 PM
HybriDNA
Sep 28, 2002 05:13 AM
