Classic Hondas All Pre-1988 Hondas.
Hazard Lights Switch?
Old May 21, 2008 | 08:45 PM
straychild's Avatar
Default Hazard Lights Switch?
The Car: 86' Honda CRX SI
I am having problems getting my hazard lights to work. My turn signals work fine. I have replaced the flasher relay but it still doesn't work. I am thinking it is in the switch. Does anyone know if the switch can be rewired to a toggle switch? Has anyone done this and what wires would I need to connect? Any help on this would be appreciated.
Old May 22, 2008 | 04:42 AM
E-AT_me's Avatar
Default Re: Hazard Lights Switch? (straychild)
check the positive battery terminal. there is a fuse and wire that go directly to the hazard switch. this is usually all corroded to hell and is the main problem.
Old May 22, 2008 | 08:40 AM
seekerONE's Avatar
If this is your problem (most likely), the easiest solution is to install a seperate inline fuse from the small single wire at the positive terminal.
Old May 22, 2008 | 08:44 PM
straychild's Avatar
Default Re: (seekerONE)
do either of you have a picture of this wire? When I did my swap I moved the battery to the back. I am wondering if this is not hooked up at all. I did look at another CRX and did not notice anything but I believe I may be missing something.
Old May 23, 2008 | 04:32 AM
E-AT_me's Avatar
Default Re: (straychild)
under the red cap, see the wires leading back? one of them is it.
Old May 24, 2008 | 07:06 AM
straychild's Avatar
Default Re: (E-AT_me)
Thanks for the help. It turned out to be the combination switch so I ended up replacing that and all is working again.
Delano Devine
Honda Civic (2001 - 2005)
Mar 21, 2009 07:41 PM
immajackuup
Apr 2, 2008 09:07 AM
3.point.2
Jul 20, 2006 06:12 AM
jakscivic
20
Jul 6, 2006 12:52 PM
ATS*Mark
16
Sep 2, 2004 05:49 PM
