good welder???
Old Jan 9, 2005 | 10:13 AM
91ls-v's Avatar
Default good welder???
i was looking into getting myself a lil welder for minor things.. but i dun't know if this welder is good or not
it'll juss be for lil stuff like exhaust and charge pipe works and mayb strut bars
http://cgi.ebay.com/ws/eBayISA...&rd=1
let me know if you guys think that will cut it...
Old Jan 9, 2005 | 10:34 AM
Engloid's Avatar
OG Fabricator
Default Re: good welder??? (91ls-v)
You'll be struggling with that little POS every time you want to weld something. It's a very weak machine with very low duty cycle. If you are doing thin sheetmetal, I'd still not advise it.
This is the equivalent of buying one of those cheap *** 100 watt pyramid amps for your stereo. In this case, you will NOT get what you DON'T pay for....
Old Jan 9, 2005 | 11:04 AM
91ls-v's Avatar
Default Re: good welder??? (Engloid)
then what is a good welder for cheap...
Old Jan 9, 2005 | 11:08 AM
spikius's Avatar
I also agree, not worth the money, a guy I know bought one, it generally welded like crap, my guess is that the duty cycle is too low and it didn't have enough adjustablility (had basically hi/lo switches for wire feed and amperage, although that one looks like it might have a bit more wire feed adjustability). I'd look at the basic miller/lincoln wire feed welders, esp. since you can add gas to them to make them mig. Flux core can be a bit tough to use well for a total beginner. I think home depot may even sell some of the lower end lincolns, which are more money than that one, but will be worth a lot more to you in the long run. Just my .02
Old Jan 9, 2005 | 11:53 AM
Engloid's Avatar
OG Fabricator
The cheapest I'd reccomend is the Hobart Handler 135. Some of the guys here mention Century welders, but I've never used one. Personally, I think that Hobart is the cheapest you can go and still get a quality piece.
noluckracing
Welding / Fabrication
12
May 7, 2010 01:19 PM
blackccoupe
Dec 28, 2008 09:57 AM
cityofcaterpillars
Nov 29, 2007 07:00 AM
stackz
23
Jan 5, 2006 09:44 PM
.Thomas
Jul 8, 2005 11:42 PM
