Flux Core Welding
Old Dec 30, 2004 | 03:48 PM
rexsk8er's Avatar
Default Flux Core Welding
Well i welded up my exhuast, and i had to do it with my stupid flux core shitty walmart welder. Is there any tricks to welding with a flux core? On any position other than flat the bead is screwed. Flat is ok, the only thing I can figure is that the shield gas from the wire is to heavy and falls away from the puddle. The welds are decient on the parts i can actually move to put in the flat position but that was only like 3 welds. Anyways next time i want to do it a little cleaner, any tips? (other than get a mig/tig )
sean
Old Dec 30, 2004 | 04:02 PM
Engloid's Avatar
OG Fabricator
Default Re: Flux Core Welding (rexsk8er)
Try welding downhill. You may have better success with it that way.
Old Dec 31, 2004 | 12:04 PM
mike_belben@yahoo.com's Avatar
From: not riding any bandwagons in, massachusetts, usa
if your welds are being effected by gravity (drippy) then pause frequently so the bead can solidify. the longer you hold the trigger, the heavier the blob and worse it will sag. 2 second squeezes with slightly higher heat, since it will cool faster during pause.
that-guy
Welding / Fabrication
12
Mar 23, 2011 09:48 AM
PolishSasquatch
14
Apr 12, 2008 10:35 AM
Mavrick
Feb 12, 2006 02:59 PM
jaydmcrx
Oct 18, 2005 06:45 PM
cdog19
Feb 3, 2004 10:39 AM
