Walking the cup for the first time. Does this look rite ?
Old Dec 18, 2004 | 01:48 PM
azfab1031's Avatar
Default Walking the cup for the first time. Does this look rite ?
So as the topic says here is my first attempt at walking the cup. Is this what it is supposed to look like? Looks good but Iam not sure ?
Old Dec 18, 2004 | 02:07 PM
untitled's Avatar
Default Re: Walking the cup for the first time. Does this look rite ? (azfab1031)
Your on the right track... Juust takes practice. Its looks to me like you need to add just a touch more filler rod and your godd to go... Use this as a guide...
Old Dec 18, 2004 | 02:44 PM
Engloid's Avatar
OG Fabricator
Not bad at all for the first try. Try and get the steps a bit closer together, kinda like in the pic posted by Untitled, above.
Old Dec 18, 2004 | 04:30 PM
Canuk_SiR's Avatar
that looks pretty good for a first try, just a little underfilled though. Not bad at all
Old Dec 19, 2004 | 12:21 PM
ExVtec's Avatar
I'm getting into welding myself....
I don't understand..."walking the cup"...?
Thanks....
Old Dec 19, 2004 | 12:33 PM
azfab1031's Avatar
Default Re: Walking the cup for the first time. Does this look rite ? (ExVtec)
Ok so I gave it another try today and used a bit more filler rod. I think Iam getting the hang of it now but Iam having a hard time getting a straight line. I guess practice makes perfect.
Old Dec 19, 2004 | 12:56 PM
Formula Racing's Avatar
Is that a pipe bomb ??
Old Dec 19, 2004 | 02:20 PM
Engloid's Avatar
OG Fabricator
That looks a little bit better, but it looks like you're rolling to one side, dabbing wire, rolling to the other and dabbing wire. Don't do it that way....lay the wire down and just roll back and forth, melting it down as you go. This will hopefully keep it from being so lumpy. Also, as you improve the technique, speed up a little and use more heat. Heat, alone, will usually make a weld smoother and reduce lumps.
Old Dec 19, 2004 | 04:14 PM
HeikDiesel's Avatar
Default Re: Walking the cup for the first time. Does this look rite ? (Engloid)
So are you just supposed to sink the tungsten back into the cup and rest the cup directly on the metal to do this?
Old Dec 19, 2004 | 05:58 PM
fulldragcrx's Avatar
Default Re: Walking the cup for the first time. Does this look rite ? (PhatAcuraIntegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhatAcuraIntegra &raquo;</TD></TR><TR><TD CLASS="quote">So are you just supposed to sink the tungsten back into the cup and rest the cup directly on the metal to do this?</TD></TR></TABLE>
I think so, ive tried it and I dont care for that method of tig welding, i cant see what the metal is doing.
Old Dec 19, 2004 | 09:09 PM
HeikDiesel's Avatar
Default Re: Walking the cup for the first time. Does this look rite ? (fulldragcrx)
Yeah I like to see how my bead is looking..Looks like you guys get good results with it tho
Old Dec 20, 2004 | 12:13 PM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fulldragcrx &raquo;</TD></TR><TR><TD CLASS="quote">
I think so, ive tried it and I dont care for that method of tig welding, i cant see what the metal is doing.</TD></TR></TABLE>
can anyone clarify?
edit.. nevermind, just read another thread. ENGLOID IS THE MAN
Modified by Dturbocivic at 4:37 PM 12/20/2004
Old Dec 20, 2004 | 04:03 PM
HeikDiesel's Avatar
Default Re: Walking the cup for the first time. Does this look rite ? (Dturbocivic)
post the link...I searched for him and found like 5 topics and none were about walking the cup
Old Dec 20, 2004 | 04:04 PM
Engloid's Avatar
OG Fabricator
No, you don't sink the tungsten in the cup. You rest the cup on the metal, but you want enough tungsten protruding from the cup so that it is at about a 30-40 degree angle, pointing towards the direction of travel. You should have no problem seeing what's going on unless you do put the tungsten in too far, or you're in the wrong position to see.
Old Dec 20, 2004 | 04:12 PM
HeikDiesel's Avatar
So you just barley stick the tungsten out and lay the torch over on the side so that the edge of the cup sits on the metal? I was always told to keep the torch at a 70-75 degree angle....wouldnt this throw that off?
Old Dec 20, 2004 | 04:13 PM
Turbo-charged's Avatar
what kind of a speed should you be going at while doing this...im guessing i go too slow is part of my "too hot" problem? is the filler rod constantly in the puddle or is it dabbed as you go along? are the zig zags done close together or fart apart?
Old Dec 21, 2004 | 12:37 PM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhatAcuraIntegra &raquo;</TD></TR><TR><TD CLASS="quote">post the link...I searched for him and found like 5 topics and none were about walking the cup</TD></TR></TABLE>
here is the thread i was reading. there is a video as well.
https://honda-tech.com/zero...age=2
Danza
Other Make Vehicles
Apr 13, 2009 04:52 PM
Punk rock mike
Jan 4, 2007 08:34 PM
ccfab
Welding / Fabrication
140
Jan 8, 2006 12:41 AM
ITR.#1446
Feb 21, 2005 01:52 PM
B16A2-EM1
Mar 20, 2003 03:45 PM
