Tig Help please
Old Jan 10, 2005 | 07:41 PM
fullblown's Avatar
Default Tig Help please
Well i was welding some mild steel today and i can run a bead pretty good, the only thing is at the end of the bead i get a crater. Is it because i let off the pedal right away??? am i suppose to feather it out at the end? any help would be appreciated thanks fellas
Old Jan 10, 2005 | 09:58 PM
Engloid's Avatar
OG Fabricator
Default Re: Tig Help please (fullblown)
Yes, taper the heat a bit slower and you won't get a fisheye.
What happens is this:
Imagine a large plate that's 12" square and you put heat directly in the middle, then you turn off the heat. The outer areas will cool down faster than the middle. The same happens in the puddle. The center is hotter, so as the outer edges cool, they shrink and suck the liquid metal towards them...leaving a hole in the middle.
if you slow the cooing at the end, it will cool slowly enough that it can't do this.
Old Jan 11, 2005 | 08:26 AM
mattssi's Avatar
Default Re: Tig Help please (Engloid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Engloid &raquo;</TD></TR><TR><TD CLASS="quote">Yes, taper the heat a bit slower and you won't get a fisheye.
if you slow the cooing at the end, it will cool slowly enough that it can't do this.</TD></TR></TABLE>
Nice way of explaining it. thanks.
Old Jan 11, 2005 | 06:36 PM
fullblown's Avatar
thanks for the reply engloid, it makes sense.
Old Jan 11, 2005 | 07:41 PM
LostCRX's Avatar
good explaination but you mispelled cooling
but yeh, he pretty much summed it up.
Jerseyfan
Jun 10, 2008 01:21 PM
VWVORTEX
Welding / Fabrication
Aug 21, 2005 05:15 AM
Turbo-charged
19
Jan 5, 2005 05:14 PM
midorigreen.
Oct 13, 2004 05:24 PM
