alarm problem....
Old Aug 26, 2008 | 08:50 PM
Dask08's Avatar
Default alarm problem....
I had a blown fuse on my alarm but I replaced it, it was a 15A fuse. then when I replaced it my alarm was working but when I turn on my car then off it wont work again only the unlock/lock button on my control works.
any ideas on what is the problem.??
its a 94 accord lx, the alarm type is viper 300 i think.
Old Aug 29, 2008 | 04:15 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: alarm problem.... (Dask08)
The car could be stuck on valet mode. Is the led staying solid or flashing if there is one?
Old Aug 30, 2008 | 06:39 PM
jz98ctr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti-eater &raquo;</TD></TR><TR><TD CLASS="quote">The car could be stuck on valet mode. Is the led staying solid or flashing if there is one?</TD></TR></TABLE>
X2 double check to see if your alarm in is "valet mode". A soild LED means you're in Valet. This made basically disables all alarm functions (including siren confirmation chirps) besides the keyless entry. If you go to replace the fuse and press lock-unlock-lock while you keep the door open...it will put the alarm into valet mode. To exit valet mode...
1. open the door
2. press lock-unlock-lock with @3 seconds or buttons 1-2-1 for older remotes
3. close the door
if the alarm WAS in valet mode then this sequence should've taken it out of valet mode....providing that your remote for the alarm is working properly.
Old Aug 31, 2008 | 05:24 AM
Dask08's Avatar
Default Re: alarm problem.... (jz98ctr)
alright I will try that because my remote only has two buttons. so yea thanx...will let ya kno if it works..
Old Aug 31, 2008 | 05:28 AM
Dask08's Avatar
tried it and didnt work. my light is a solid red, any other ideas on how to make it work again?
everytime I unplug and plug the fuse it works like normal. Dont seem why it malfunctions after I turn on the car then off.
Old Aug 31, 2008 | 05:52 AM
fcm's Avatar
fcm
Old Fart
http://www.directeddealers.com...V.pdf page 10.
As mentioned press button I the II then I again, you can also turn ing. switch on the off again then press and release the valet program button, [hidden under the dash].
If the neither of the above work it's a good bet you do not have a Viper 300, you will need to stick you head up under the dash and find the alarm brain to see what the model is. 94
Old Sep 1, 2008 | 06:16 AM
Dask08's Avatar
Default Re: alarm problem.... (fcm)
it is a 300 but still no way to fix it. I'm just gonna replace it for a better one.
PurpleAccord88
Dec 6, 2007 12:01 PM
JasonST
Audio / Security / Video
Apr 28, 2007 04:07 PM
Nameless Warrior
17
Feb 24, 2007 08:42 AM
StrtMeUp01
Sep 20, 2005 12:23 PM
StrtMeUp01
Sep 19, 2005 03:31 PM
