radio problem need help
ok i had a pioneer premier radio real nice n e ways got rid of it and i decieded to connect the factory radio to my amps. now i've just been having problems ok when i first put the factory radio to the amps it was working fine for like a half hour and then both amps went to protect. now the crazy thing is if leave the amp for the subs connect and disconnect the power wire from the highs it works fine and then if you do the opposite the same thing happens. wtf why can't both amps work together?
set up is 2 10" cerwin vega vmax subs,sealed box, 2 phoenix gold amps 1) v8001 mono amp 2)v754 4ch. amp i have the rockfordfosgate 4gauge dual amp kit and now the factory radio with that scosche kit to run the amps to the factory radio. like i said the system was fine with the pioneer radio until i tried running it with the factory radio
hey, i have the same problem but after roughly 15 minutes the sound stops on everything but everything still has power, then i turn the cd player off then on again and sound comes back? help? anyone.
themiccivic
Acura TL, RL & ZDX
May 16, 2009 05:04 PM
christian7750
Audio / Security / Video
Apr 24, 2009 06:44 AM
patrick4588
11
Feb 18, 2008 09:33 PM
IneedBoostInTheCoupe
Jul 4, 2007 08:52 PM
