Complete kill switch (safty switch?)
I am wanting to install a switch, to where when you turn the key over nothing works unless you turn the hidden switch on, what's the easiest way to install this, thanks for reading and your help ahead of time.
What do you mean by "nothing works"?
If you mean no power to anything at all, it would mean you will need a batt. switch... http://www.batterymart.com/p-b....html not recommended as you will loose all memory to HU and ECU/ECM and although not a big deal it is definitely a pain in the *** to reset everything every time you use it.
There are better options.
94
94
i mean if you really want that .... you would put a relay inline of one of the wires coming off the cylinder harness ..... but i would just recommend putting a relay on the 12v wire for ur fuel pump .... i pmd you about the tuck and i can also talk to you more about this when you pm me back
