ignition harness question
Old Sep 18, 2008 | 11:41 AM
Hanmin's Avatar
Default ignition harness question
searched, couldn't find it, having a cigarette lighter problem. checked fuse, blah blah. 1995 civic cx, I was wonder what the white wire with a black stripe on it does, I know the black wire with the white stripe is the starter, whats the white wire with a black stripe?
Old Sep 18, 2008 | 12:33 PM
B18C_EJ8's Avatar
Default FV-QR
12 VOLT CONSTANT WHITE (+) IGNITION SWITCH HARNESS
STARTER BLACK/WHITE (+) IGNITION SWITCH HARNESS
STARTER 2 N/A
IGNITION 1 BLACK/YELLOW (+) IGNITION SWITCH HARNESS
IGNITION 2 N/A
IGNITION 3 N/A
ACCESSORY/HEATER BLOWER 1 YELLOW (+) IGNITION SWITCH HARNESS
ACCESSORY/HEATER BLOWER 2 N/A
KEYSENSE N/A
PARKING LIGHTS ( - ) N/A
PARKING LIGHTS ( + ) RED/BLACK (+) @ FUSEBOX OR DRIVERS KICK PANEL
POWER LOCK GREEN/WHITE (TYPE B) @ 2-PIN BLUE PLUG, BEHIND FUSEBOX
POWER UNLOCK GREEN/RED (TYPE B) @ 2-PIN BLUE PLUG, BEHIND FUSEBOX
LOCK MOTOR WIRE N/A
DOOR TRIGGER LIGHT GREEN/RED (-) IN DRIVERS KICK PANEL
DOMELIGHT SUPERVISION USE DOOR TRIGGER, Requires Part #775 Relay
TRUNK RELEASE N/A
SLIDING POWER DOOR N/A
HORN BLUE/GREEN (-) or BLUE/RED (-) @ STEERING COLUMN HARNESS
TACH BLUE @ 2-PIN PLUG NEAR DISTRIBUTOR
WAIT TO START LIGHT N/A
BRAKE GREEN/WHITE (+) @ SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM N/A
ANTI-THEFT N/A
I don't see a white/black... Get your meter out & test it.
Old Sep 18, 2008 | 12:54 PM
Hanmin's Avatar
its a 12v source when the car is in acc or run. it gives power to the cigarette lighter forsure, and im pretty sure it gives power to the deck too.
Old Sep 18, 2008 | 12:56 PM
B18C_EJ8's Avatar
Default FV-QR
Then it's probably a second accessory.
Old Sep 18, 2008 | 08:31 PM
fcm's Avatar
fcm
Old Fart
Default Re: ignition harness question (Hanmin)
" I was wonder what the white wire with a black stripe on it does" On what, the lighter or the ign. switch?
Also, what is the problem you are having with the lighter? 94
Old Sep 19, 2008 | 06:07 AM
Hanmin's Avatar
ignition, and my lighter wasnt working because i accidently spliced that wire instead of the black with white stripe when i put in my remote start. and that wire got disconnected.
EFPimpin
Audio / Security / Video
Sep 17, 2010 03:55 AM
4EN[sic]
Mar 9, 2007 05:09 AM
x00gsr
17
Mar 14, 2003 07:23 AM
yoshi234
Feb 12, 2003 08:29 AM
