Amp Not Turning On.....wtf
Old Sep 23, 2008 | 07:39 AM
The G2 Racer's Avatar
Default Amp Not Turning On.....wtf
Moved my amp yesterday to a little more stealth spot.
Now it's not turning on.
Checked the fuse, that's good. Checked the trigger/remote wire and that's good.
I'm thinking it's the ground, it's grounded to the seat mounting bolt, metal under the mount is sanded down to bare metal.
Ideas?
It's a 93 Integra.
Old Sep 23, 2008 | 09:47 AM
honda_joe's Avatar
Default Re: Amp Not Turning On.....wtf (The G2 Racer)
Did you check the trigger wire with a volt meter?
I'd also check the power wire with a volt meter and the ground wire with an OHM meter and verify continuity to chassis ground.
Old Sep 23, 2008 | 10:11 AM
Default Re: Amp Not Turning On.....wtf (honda_joe)
I don't have a volt meter sadly.
The only connection that changed is the ground, hence why I'm suspecting that. Maybe I should pull the seat out again and go to town on sanding it down and sand down the back of the mount too.
Old Sep 23, 2008 | 12:07 PM
So I took it all apart again. Re-did the connections at the amp, sanded down the ground more.
Went under the hood to remove the fuse in the power line and that's when I noticed the fuse holder was ****, cracked and falling apart. I removed the center piece so the fuse was making contact and sure enough it work.
I will buy a new one in the next few days and replace it.
Old Sep 23, 2008 | 07:17 PM
NVturbo's Avatar
O.G. triple O.G.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The G2 Racer &raquo;</TD></TR><TR><TD CLASS="quote">I don't have a volt meter sadly.
The only connection that changed is the ground, hence why I'm suspecting that. Maybe I should pull the seat out again and go to town on sanding it down and sand down the back of the mount too.</TD></TR></TABLE>If you can find a good ground near your amp, use that instead. All my audio installs, I have never had to sand down for a good grounding point. Any threaded hole with the proper bolt will do fine. Just make sure the area is solid metal, not flimsy paneling.
Old Sep 23, 2008 | 07:28 PM
Default Re: Amp Not Turning On.....wtf (NVturbo)
I've always sanded it down.
Everything is working mint now.
froogle29
Audio / Security / Video
Oct 29, 2009 07:44 PM
Skeletor
Sep 6, 2007 09:50 AM
Ronin Integra8
Jun 3, 2003 05:18 PM
NA EJ1
Sep 20, 2002 08:39 PM
Understeer
Aug 23, 2002 03:04 PM
