Problem with Viper 5900 install
Old Sep 10, 2008 | 08:33 AM
Mrmatt3465's Avatar
Default Problem with Viper 5900 install
After reading the write up on stealth install I decided to take on the task of moving components and such to a more stealth location other then the generic places done by a car audio place. I disconnected the brain and moved it to another location. I rewired everything and began to test it.
I had a problem with the test. My remote did not comunicate with my alarm. I hit lock or unlock with the doors closed and the remote indicates that it is not sending or receiving signal.
Does anyone have an idea what I may have done incorrectly? If so is it a simple fix? If not, then I will most likely begin tearing out the alarm completely and starting over using the write up.
Thanks!
Matt
Old Sep 10, 2008 | 10:57 AM
kleen98accord's Avatar
Default Re: Problem with Viper 5900 install (Mrmatt3465)
Double check you wires and their connections.
Old Sep 10, 2008 | 10:59 AM
fcm's Avatar
fcm
Old Fart
You either forgot to plug the ant. back into the brain, or the remote(s) need to be reprogrammed... http://www.directeddealers.com...t.pdf page 34-35 use #1 standard configuration 94
Old Sep 10, 2008 | 01:37 PM
baller status's Avatar
Verify your power and ground with a multimeter.
BayAreaBB6
Audio / Security / Video
Feb 5, 2008 01:06 PM
sickofitall1113
17
Sep 9, 2007 10:33 AM
t0ekn3e
Dec 28, 2005 09:35 PM
2camsaam
Sep 11, 2003 09:15 AM
yellowbuffalo
Jan 1, 2002 11:12 PM
