sub/amp issues
Old Sep 15, 2008 | 01:00 PM
logeywartooth's Avatar
Default sub/amp issues
i have everything wired up but it wont turn on. the fuses are good. the only time the power light on the amp will flash on is when i touch the ground wire to amp plug in. it doesn't stay on. it worked yesterday.
Old Sep 15, 2008 | 01:02 PM
Brad_and_the_acc's Avatar
Default Re: sub/amp issues (logeywartooth)
Make sure your connections are good. And double check them and make sure they are good again. Then tell us what you find.
Old Sep 15, 2008 | 01:13 PM
Default Re: sub/amp issues (Brad_and_the_acc)
the power, and remote wires are good. i have the ground attached beneath the carpet to the metal with a screw. when i move it and touch it to metal it sparks. thats when the light flashes on.
Old Sep 15, 2008 | 01:15 PM
TheMuffinMan's Avatar
He knows where you live!
So your ground wire isn't grounded?
Sand off the paint where it's connected and reattach it.
Old Sep 15, 2008 | 01:23 PM
Default Re: (TheMuffinMan)
it should be grounded, its attached directly to the metal.
Old Sep 15, 2008 | 01:25 PM
From what you just described, moving it across metal sparks it so your ground is probably bad.
That or you blew an internal fuse for the amp.
Old Sep 15, 2008 | 02:35 PM
02 accord's Avatar
Probably a bad ground. If he blew a fuse, it wouldn't even spark.
Old Sep 15, 2008 | 04:04 PM
Default Re: (02 accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02 accord &raquo;</TD></TR><TR><TD CLASS="quote">Probably a bad ground. If he blew a fuse, it wouldn't even spark.</TD></TR></TABLE>
Depending on the setup I guess, If he had a capacitor in between the amp and the power it would still spark. But good point if it was directly to the amp.
Old Sep 15, 2008 | 06:48 PM
ws350z's Avatar
I attached my ground to one of my trunk bolts and had no probs just rub off some of the paint to make sure the wire is flush with the metal
Old Sep 16, 2008 | 12:19 AM
schmiddr2's Avatar
Default Re: (logeywartooth)
Sounds like a weak ground, but anytime the power light flashes that's usually not a good thing. I have blown many amps "testing" things the way you are.
froogle29
Audio / Security / Video
Oct 29, 2009 07:44 PM
pooMan
20
May 22, 2006 09:10 AM
lilman36
Oct 4, 2003 01:47 PM
Skitals
18
Sep 16, 2003 08:27 PM
BoroDB8
Oct 15, 2001 01:09 AM
