Alarm Problem
Old Sep 8, 2008 | 08:01 PM
Locc's Avatar
Default Alarm Problem
Change my car battery recently now my doors dont lock or unlock with the alarm.
Car - 2001 ITR
Alarm - Clifford RS3.5
I check all the fuses and everything else. The alarm arms and disarms fine except it doesn't lock or unlock the car. I check the door trigger and the wires to the the alarm, what else can it be?
Old Sep 9, 2008 | 05:51 AM
fcm's Avatar
fcm
Old Fart
Default Re: Alarm Problem (Locc)
Are they stock power door locks, or aftermarket?
If stock, does the stock power door lock switch on the door work? 94
Old Sep 9, 2008 | 11:00 AM
Locc's Avatar
Default FV-QR
I have the jdm lock switch deletes so theres no way i can confirm that, and I have db8 rear handles so i cant test the key manually
Old Sep 9, 2008 | 11:24 AM
fcm's Avatar
fcm
Old Fart
Default Re: FV-QR (Locc)
OK, what is the MM&Y of the car and the make and model of the alarm? 94
Old Sep 9, 2008 | 05:27 PM
Locc's Avatar
Default FV-QR
the mmy and model is in the original post
Old Sep 10, 2008 | 05:40 AM
fcm's Avatar
fcm
Old Fart
Do you mean the Clifford Matrix RSX3.5... http://www.directeddealers.com...5.pdf
If so, the alarms power door lock interface with the cars door lock wiring should be under the drivers kick panel at the bigger of the two gray plugs, the alarms wires are green, [lock] and blue, [unlock] they should be connected green to black/white and blue to black/red, I would also make sure the door lock plug is plugged into the alarm brain properly.
If all the above is good then you will need to get to the power door lock switch plug and plug the switch back in and try it, or you can just use a jumper wire from the black lead to the green/white and green/red leads to test the system, if that does not work you still have a blown fuse, make sure you have power at both ends of the power door lock fuse. 94
Old Sep 10, 2008 | 11:08 PM
yan_david's Avatar
Hi, Did the installer use the door lock relay? If he did there is a fuse there. The color of the wire is PURPLE/BLACK and the size of the fuse is 15amp.
Old Sep 14, 2008 | 01:01 AM
Locc's Avatar
Default FV-QR
I use a probe, test all fuses it was good, grounded the switch under the panel still doesnt work, try to jump the motor itself but still no go, the motor sound like its going to click over but does nothing. also check all the alarm wiring it gives off power everything is still good. still stump anything else i can check
mickey513
Audio / Security / Video
Mar 12, 2014 03:10 PM
crx98
May 14, 2008 01:25 PM
evo1234
Apr 25, 2006 05:42 AM
Dub C
Apr 4, 2006 08:42 AM
slowturtle
Apr 29, 2005 06:59 AM
