tach signal???
Old Aug 27, 2008 | 07:41 AM
hialeahzbg's Avatar
Default tach signal???
a friend of mine installed a clifford g5 770 last nite on my 2007 civic si...the only problem is that we couldnt find the tach signal wire to install the blackjax...can any of u alarm gurus help me find this on my 2007 civic? pics would be great since i dont know much about K's...
Old Aug 27, 2008 | 08:14 AM
B18C_EJ8's Avatar
Default FV-QR
TACH NOT BLACK/WHITE, BLACK or YELLOW/BLACK @ ANY IGNITION COIL or FUEL-INJECTOR
Old Aug 27, 2008 | 08:15 AM
hialeahzbg's Avatar
lol i got confused...so what color is the wire on the injector?
Old Aug 27, 2008 | 08:18 AM
B18C_EJ8's Avatar
Default FV-QR
I dunno. Why don't you run out there and take a look?
I posted what wires NOT to use.
Old Aug 27, 2008 | 08:20 AM
hialeahzbg's Avatar
lol because u completely lost me...u said not to use any of those on the ignition coil and injectors?
Old Aug 27, 2008 | 08:32 AM
B18C_EJ8's Avatar
Default FV-QR
LOL... And you put an alarm in?
I guess copying & pasting from another site isn't helping you, so let me rephrase.
On the injectors & coils, there will be two wires on each.
For tach signal, you can use ANY of those 8 wires, EXCEPT for any wires that are Black/White, Black or Yellow/Black.
Get it?
Old Aug 27, 2008 | 08:35 AM
hialeahzbg's Avatar
lol no i didnt install it...as u can read im horrible when it comes down to wiring...one of my boys did but he said he couldnt find it on my car to install the blackjax...so any of the 8 wires on the injectors...got it...thanks man i appreciate it...
Old Aug 27, 2008 | 08:40 AM
B18C_EJ8's Avatar
Default Re: (hialeahzbg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hialeahzbg &raquo;</TD></TR><TR><TD CLASS="quote">so any of the 8 wires on the injectors...got it...thanks man i appreciate it...</TD></TR></TABLE>
NO, you DON'T got it...
That is NOT what I said.
If you use the wrong wire, you WILL burn out the coil or injector that wire is connected to.
Old Aug 27, 2008 | 08:41 AM
hialeahzbg's Avatar
ok just popped my hood and i see that in the 4 injectors theres a yellow/black wire in each of them and theres a solid color wire as well...
Old Aug 27, 2008 | 08:42 AM
hialeahzbg's Avatar
lmao so it must be any of the solid color ones...because the other one is yellow/black....now i get it! whats that yellow/black wire?
Old Aug 27, 2008 | 10:00 AM
hialeahzbg's Avatar
lol so comfirming its the solid colored wire out of the 2 wires on the injector....
Old Aug 27, 2008 | 10:54 AM
fcm's Avatar
fcm
Old Fart
The yellow/black is 12V+ power from the OGM-FI Main Relay, the "solid color" or the wire that is a diff. color on each injector, [anyone of those is what you want to use] is the ground control from the ECU/ECM, that lead will have the "pulse" the tach input needs to monitor the engines RPM. 94
Old Aug 27, 2008 | 11:19 AM
hialeahzbg's Avatar
awesome....i called my installer and he said he connected it to the solid color black wire in the injector...why wouldnt it pick up the rpms then so the blackjax activates?
Old Aug 27, 2008 | 12:10 PM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hialeahzbg &raquo;</TD></TR><TR><TD CLASS="quote">i called my installer and he said he connected it to the solid color black wire in the injector...why wouldnt it pick up the rpms then so the blackjax activates?</TD></TR></TABLE>
Jesus.. I give up....
You and your installer are idiots....
The reason it's not working is because the pretty black wire is one of the ones that you DON'T hook tach to.
I suggest removing that wire immediately before you burn out that injector.
Old Aug 27, 2008 | 12:18 PM
hialeahzbg's Avatar
thats why im asking...sorry for asking so many question but the reason why i am asking is because i dont know...so chill out with the idiot remark....can he do it with the blue wire instead?
Old Aug 27, 2008 | 12:38 PM
B18C_EJ8's Avatar
Default FV-QR
Truly.. I give up.
I've already stated twice what colors you can't use. If you or your "installer" can't figure it out, and don't know the meaning of the word "except", then that's your problem.
I just don't know how else to explain it....
Just ******* read.
Old Aug 27, 2008 | 12:44 PM
02 accord's Avatar
Default Re: FV-QR (B18C_EJ8)
Lol.
Old Aug 27, 2008 | 03:18 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: FV-QR (02 accord)
This has go on to far, the op and the installer need to give this up and seek professional. How can a installer not figure this easy step out. let alone have the answer thrown in the face and stiol can't figure this out.
Old Aug 27, 2008 | 05:22 PM
B18C_EJ8's Avatar
Default FV-QR
I'm waiting for the "I'm the installer and you don't know what you're talking about" or the "I didn't listen to what you said and now my car runs like **** because I burned out an injector" posts...
Old Aug 28, 2008 | 04:38 AM
fcm's Avatar
fcm
Old Fart
TACH... NOT BLACK/WHITE, BLACK or YELLOW/BLACK @ ANY IGNITION COIL or FUEL-INJECTOR
To be clear, use any wire but DO NOT USE a black, black/white or black/yellow
Sorry for yelling but I can't make this any clearer, if your installer can't figure it out, maybe you need to find another installer. 94
Old Aug 28, 2008 | 05:56 AM
hialeahzbg's Avatar
ok i understand it and no my installer wont come in here saying anything...im obviously asking because i dont know...its not on a black/yellow wire...
Old Aug 28, 2008 | 07:16 AM
White Smoke's Avatar
i my honda
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> TACH... NOT BLACK/WHITE, BLACK or YELLOW/BLACK @ ANY IGNITION COIL or FUEL-INJECTOR
This is as clear as it gets... You know what a injector wire is right? There are two going to each injector. Tap into the wire that is NOT BLACK. I think the yellow black and black white wires are on the coil packs. Each injector will have one different color wire going to the ECU, and one black wire that goes to ground. You want the wire that goes to the ECU.
Old Aug 30, 2008 | 06:52 PM
jz98ctr's Avatar
Default Re: (White Smoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke &raquo;</TD></TR><TR><TD CLASS="quote">
This is as clear as it gets... </TD></TR></TABLE>
DO NOT USE BLACK/WHITE
DO NOT USE BLACK
DO NOT USE BLACK/YELLOW
an injector usually has 2 wires...if one of those 2 wires has any black on it...DON'T use it
fukc blackjax anyways
Old Aug 31, 2008 | 12:39 AM
Default Re: (jz98ctr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jz98ctr &raquo;</TD></TR><TR><TD CLASS="quote">
DO NOT USE BLACK
fukc blackjax anyways</TD></TR></TABLE>
Really blackjax is very anoying. It does nonething for security imo. Really only usefull in high carjacking areas, Most dei alarms have arm while driving.
civic_speed99
Audio / Security / Video
Dec 18, 2007 03:44 PM
lsvtek
10
Aug 23, 2006 08:56 PM
arbys2k
Honda S2000
May 5, 2006 02:07 AM
HONDA_TYPE_R
Oct 31, 2004 01:45 PM
rex03
Jan 10, 2004 11:24 AM
