where do u put a amp in a Del sol?
Old Aug 18, 2008 | 03:31 PM
pinoy2o9's Avatar
Default where do u put a amp in a Del sol?
where would be the best place to put a 4 channel amplifier in a honda del sol? easy to get to, safest place, etc.... thanks in advance.
Old Aug 18, 2008 | 04:29 PM
fcm's Avatar
fcm
Old Fart
Default Re: where do u put a amp in a Del sol? (pinoy2o9)
Under pass. seat. 94
Old Aug 18, 2008 | 05:31 PM
pinoy2o9's Avatar
Default Re: where do u put a amp in a Del sol? (fcm)
wut amps will fit under the seats? i mite swap s2000 seats tho. duno if that makes any difference?
Old Aug 19, 2008 | 04:37 AM
fcm's Avatar
fcm
Old Fart
You may have to raise the seat, [spacers/brackets/longer bolts] but just about any amp will fit, obviously the smaller the amp is and the lower it's profile, the easier it will be.
Alpine PDX amps are, • Heat Sink (WxHxD) in: 10-1/8" x 7-9/16" x 2-7/16"
JL Audio HD amps are even slimmer, 10.74 in. x 8.29 in. x 1.93 in. 94
Old Aug 19, 2008 | 05:30 AM
White Smoke's Avatar
i my honda
Global Mod
You will have the same amt of room with the S2000 seats as the del sol seats.
Old Aug 20, 2008 | 08:22 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: where do u put a amp in a Del sol? (White Smoke)
when i had my del sol, i mounted it to the flat part that sits parallel to the back of the seat. theres simply not enough room under the seat for the amp.
Old Aug 20, 2008 | 05:28 PM
fcm's Avatar
fcm
Old Fart
Default Re: where do u put a amp in a Del sol? (AzntaggeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzntaggeR &raquo;</TD></TR><TR><TD CLASS="quote"> theres simply not enough room under the seat for the amp. </TD></TR></TABLE> Yes there is, although you may have to raise the seat a little, or a lot, I once installed a H/K amp under the pass seat, [over 3" tall], nothing a few spacers, custom brackets and longer bolts couldn't solve. 94
Matthew_zero
48
Sep 15, 2007 05:34 AM
skUnK2jdm
Aug 20, 2007 07:34 PM
541delSol
Audio / Security / Video
Jun 23, 2003 07:48 PM
spencedogg
Apr 27, 2003 04:47 PM
spencedogg
Apr 27, 2003 04:32 PM
