fuel pump kill switch
Old Sep 9, 2008 | 09:44 PM
jdmjin's Avatar
Default fuel pump kill switch
I was wondering if you have to use a relay when making a kill switch for the fuel pump? The reason I am asking this question is because I researched this topic and the information I got kinda confused me!!!
In some there is no relay used, they just have a switch that interrupts the power to the fuel pumps.... and in others there is a relay used that goes back to the alarm!!!
So, my question is can I make a kill switch without using a relay and still be save from any fires???
Old Sep 10, 2008 | 06:06 AM
fcm's Avatar
fcm
Old Fart
Default Re: fuel pump kill switch (jdmjin)
If you want it connected to an alarm you will need a relay if you want to just add a switch a relay is not needed if you install the switch on the ground to the PGM-FI Main Relay or the switch is installed close to the power lead to the fuel pump, [and the switch id "big" enough. a relay would be needed if the wire run to and from the switch is too long. 94
Old Sep 11, 2008 | 09:50 AM
jdmjin's Avatar
Default Re: fuel pump kill switch (fcm)
ok kool....im just going to use a smalle switch....How long can it be before I have to use a relay?
Old Sep 11, 2008 | 11:31 AM
fcm's Avatar
fcm
Old Fart
If you are going to install the switch on the ground to the PGM-FI Main Relay then it makes no real diff. on how long the leads are as it is a low current ground, if you want to put it on the fuel pumps power lead then any more then 3' away, [6' of wire] I would install a relay. 94
Old Sep 11, 2008 | 03:35 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">If you want it connected to an alarm you will need a relay if you want to just add a switch a relay is not needed if you install the switch on the ground to the PGM-FI Main Relay or the switch is installed close to the power lead to the fuel pump, [and the switch id "big" enough. a relay would be needed if the wire run to and from the switch is too long. 94</TD></TR></TABLE>
Take this mans advice. Its better then the fuel pump wire kill. I been preaching this for a min and so has fcm. It harder if not inpossiable to bypass a alarm with the main relay killed. This kills the fuel pump, injectors and part of the ecu. Its three in one. Use this with a alarm system and you will have a very protected car.
Old Sep 11, 2008 | 09:23 PM
jdmjin's Avatar
Default Re: fuel pump kill switch (wrx-killer-Sti-eater)
Would you know where i can find a diagram to do that? The reason I'm asking is because I don't want to have a short causing a fire by the fuel pump....and I want to have my car fully protected!!!
Old Sep 12, 2008 | 04:47 AM
fcm's Avatar
fcm
Old Fart
If you install the switch on the ground for the PGM-FI Main Relay then there is no possibility of either a short or fire as you are dealing with a low current ground.
As for w wiring diagram, it is not needed, cut ground lead install switch, one cut lead to each terminal of a SPST, [on/off] switch.
Old Sep 12, 2008 | 01:37 PM
jdmjin's Avatar
The main realy is near the fuse box under the dash right?
Old Sep 12, 2008 | 03:24 PM
fcm's Avatar
fcm
Old Fart
That depends on the MM&Y of car. 94
Old Sep 14, 2008 | 08:20 PM
jdmjin's Avatar
Well its a 92 civic hatch si!
Old Sep 15, 2008 | 04:47 AM
fcm's Avatar
fcm
Old Fart
Then yes, it should be just to the left of fuse box, just above and behind hood release. 94
dgdarien
Audio / Security / Video
Apr 12, 2009 12:03 PM
5lugSlug
Sep 18, 2005 12:25 PM
VTECorona
Aug 27, 2003 05:50 PM
fred92htch
Aug 15, 2002 12:53 PM
Christine
Oct 1, 2001 08:38 AM
