remote start help!!!
Old Aug 19, 2008 | 02:54 PM
doggworld1233's Avatar
Default remote start help!!!
alarm autopage rs 727
car is a 99 tahoe
used i data link bypass.
problem is car will start then the starter will continue to run. i programed the tach sig 3 times by on/off 3 time then vallet 11 times holding on the 11th then holding lock and unlock then pressing unlock then starting the car then pressing the vallet button then turning off the car and pressing lock to exit.
thanks in adv for any help.
Old Aug 19, 2008 | 04:43 PM
fcm's Avatar
fcm
Old Fart
Default Re: remote start help!!! (doggworld1233)
Where are you getting the tach signal from? 94
Old Aug 19, 2008 | 04:57 PM
white wire on the coil located on pass back side of the motor. led flashes when car is started
Old Aug 20, 2008 | 04:32 AM
fcm's Avatar
fcm
Old Fart
Default Re: (doggworld1233)
Either you have the wrong white lead, tach signal on the white lead is not strong enough or there is a problem with the R/S brain, move your tach pickup lead to one of the fuel injectors, [use lead that is a diff. color at each injector] any injector will work. 94
Old Aug 21, 2008 | 06:37 AM
fixed problem. changed tach to voltage sense and had acc wired to the starter.
laziebun
Audio / Security / Video
Nov 9, 2010 02:45 PM
fcm
21
Sep 4, 2009 09:20 AM
96teggynonVtec
22
May 22, 2007 09:06 PM
superthug
Oct 29, 2006 05:06 PM
jodykw1982
May 2, 2004 06:02 PM
