static noise when braking
Old Sep 16, 2008 | 02:48 PM
Agito's Avatar
Default static noise when braking
Hey guys, not sure where to begin looking. I get a static noise thru the speakers whenever I brake and going over some heavy bumps. Obviously sounds like a grounding issue but where to start?
Old Sep 16, 2008 | 09:41 PM
WickedKP's Avatar
Default Re: static noise when braking (Agito)
where to start?
Well a little better detail about what u have might be a good start.
do u have amp(s)
what headunit are u using.
is the static noise coming from all speakers even subs?
Old Sep 17, 2008 | 12:17 PM
Agito's Avatar
Default Re: static noise when braking (WickedKP)
Everything is stock cept for the head unit which is a Clarion SD player and i used a harness for the wiring. Just started happening after we finished tuning the car on the dyno. lots of vibration at 10k rpm so i'm thinking something got loose but no idea what would cause this everytime i brake now and only some big bumps. It seems to be coming from the rear except at times it sounds like its cutting out from the HU itself and no sound comes from any speaker... The wires were soldered and not crimped. no amps in this setup
Modified by Agito at 3:12 PM 9/17/2008
Old Sep 17, 2008 | 06:25 PM
WickedKP's Avatar
I would suggest remove the head unit from the dash wired up still move the harness around and kind tap on the head unit. If everything is stock it is very unlikely to come loose. Look at your rear speaker wire from the trunk possibly it could be touching. I ran into once where the speaker tensile was barley touching the frame of the speaker frame causing a short off and on.
Old Sep 18, 2008 | 07:52 AM
Agito's Avatar
cool thanks, thats exactly what it was.. the speaker wire.
Old Sep 18, 2008 | 09:31 PM
WickedKP's Avatar
No problem
killahatch
Audio / Security / Video
Aug 2, 2009 01:19 PM
AK Macster
Feb 8, 2009 08:03 PM
romoracing
15
Aug 19, 2005 07:03 AM
nver2
May 14, 2004 01:49 PM
