help with sub problem.
Old Sep 10, 2008 | 05:26 PM
ef_88_hatch's Avatar
Default help with sub problem.
when i turn the volume up on my head unit the subs will shut down like they have no power but the amp is still on. all the speakers in the car still work fine but the subs just shout down.
also if i turn the headunit off then back on the subs will turn back on untill the subs start i hit then they shut down again.
Old Sep 10, 2008 | 06:11 PM
fcm's Avatar
fcm
Old Fart
Default Re: help with sub problem. (ef_88_hatch)
Sounds like amp is going into "protection mode".
What is the make and model of the amp and sub? 94
Old Sep 10, 2008 | 06:19 PM
alpine subs and amp. i am not sure of the model its my gf car so i cant even check right now. i am wondering if the ground and power wire are not large enough.
Old Sep 10, 2008 | 06:20 PM
what would make it go in to protection mode?
Old Sep 10, 2008 | 11:11 PM
yan_david's Avatar
Hi, There could be a couple of reason it would go into protection mode. One is the ground and the other one is the way you wire you subwoofers.
Old Sep 11, 2008 | 08:31 AM
NVturbo's Avatar
O.G. triple O.G.
just like fcm said...your amp may be in protection mode. If the amp is running at a lower impedance than normal, it will do that. For example, a while back I was running a Punch 100DSM on a JL Audio 12w4...running at 4 Ohms mono. When I replaced the sub for a 12w6, I ran the amp at 3 Ohms mono. It played for a bit and then it shut off. That may be your problem also.
Old Sep 12, 2008 | 02:35 PM
the ground and every thing is good i know that. so how should the sub's be wired. right know i have them briged? i am not sure how you would change the Ohms. i am a real *** to systems.
Old Sep 12, 2008 | 03:15 PM
fcm's Avatar
fcm
Old Fart
You do not bridge the subs, you bridge the amp, the subs are wired in parallel or in series, or a combination of both parallel and series.
When you wire in parallel the impedance, [ohms] drops, EG; two 4 ohm speakers wired in parallel is a 2 ohm "final" load, wire the same two speakers in series and the impedance will be 8 ohms "final" load.
If you have DVC, [dual voice coil] subs you may want to wire them in a combination of both parallel and series, EGl; you have two DVC 4 ohm subs, you would wire the VCs on each sub in series, [4+4 in parallel=8] for an 8 ohm load, then wire the two subs in parallel, [8+8 in series=4] for a "final" load of 4 ohms.
That is why we need the model number of the subs and how they are wired.
If you have a 2ch Alpine amp and it is bridged into mono, [1 channel] it is not stable below 4 ohms, so if the subs are wired to below 4 ohms the amp will over-heat and the amps thermal protection circuit will cut in an turn off the amps output stage to protect it, that will happen a lot quicker at higher volume levels. 94
Old Sep 12, 2008 | 06:12 PM
incubus's Avatar
Default Re: help with sub problem. (fcm)
you could also possibly have a dead short in your sub. try a different sub.
Old Sep 13, 2008 | 06:32 AM
Dask08's Avatar
oh damn I have that problem too on my subs and they are bridge. I have a 2000 2ch amp running two alpine type s 900 watts each and 300-500 rms on each. which they are bridged into .5 ohms. that aint good is it? because my subs keep shutting down if I bump it too loud. we have the same problem dude just try to run each sub on each channel ima try that too.
Old Sep 13, 2008 | 11:37 AM
fcm's Avatar
fcm
Old Fart
Default Re: help with sub problem. (Dask08)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">You do not bridge the subs, you bridge the amp, the subs are wired in parallel or in series, or a combination of both parallel and series.</TD></TR></TABLE>
Alpine makes 4 Type S subs, [two 12" and two 10"] in DVC 4 ohm and DVC 2 ohm, which ones do you have?
BTW they are 300W continuous, [RMS] not "300-500 rms", Power Range is 50-300 watts.
With DVC 4 ohms two of them can be wired to 1 ohm 4 ohms or 16 ohms.
With DVC 2 ohms two of them can be wired to .5 ohms 2 ohms or 8 ohms.
It sounds like you have DVC 2 ohms wired in parallel/parallel, [.5 ohms], it is unlikely your 2ch amp is stable below 4 ohms when bridged, much less .5 ohms.
Wiring one sub to each channel of the amp may be your only option, but it is not the best way to drive two subs.
What is the make and model of the amp? 94
Old Sep 13, 2008 | 12:24 PM
i do not under stand all the ome stuff like i said im new to the system thing. if it dont run i can fix it but this is not my thing.
right know i have the two subs wired sub + to amp - and sub - to amp + on both
is this right or wrong.
here is the subs i have.
http://www.woofersetc.com/inde...=2927
here is the amp i have in there right now i took my big amp out. i did not want to burn it up.
http://www.woofersetc.com/inde...=3732
Old Sep 13, 2008 | 12:48 PM
fcm's Avatar
fcm
Old Fart
Could have sworn you said...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef_88_hatch &raquo;</TD></TR><TR><TD CLASS="quote">alpine subs and amp. </TD></TR></TABLE>
Anyway they are DVC 4 ohm subs, and should be wired series/parallel, wire the VCs of each sub in series, [connect the pos.(+) of one VC to the neg.(-) of the other VC, that will leave to with the neg.(-) of one VC and the pos.(+) of the other VC] that will be an 8 ohm impedance on each sub, then wire the two subs together in parallel, [the two pos.(+) together and the two neg.(-) together] to the amp.
This may help... http://mobile.jlaudio.com/supp...d=161
Use 2 DVC drivers with Voice Coils in Series / Parallel.
The amp you have now is way under-powered, you have two 400W subs, [800W] on an amp that will make 220W RMS into 4 ohms and is not stable below 2 ohms.
What is the make and model of your "big amp"? 94
Old Sep 13, 2008 | 12:53 PM
ya i know i went to the car and looked at the subs and amp ant they are both infinty before i took my big amp out. my bad. but thanks for all your help.
Cory Matthews
Audio / Security / Video
22
Mar 6, 2006 02:13 PM
notguilty411
15
Apr 5, 2005 01:56 PM
Arsenal
Mar 9, 2004 07:06 PM
Feuerraeder
Dec 24, 2002 09:06 AM
raene
Jul 23, 2001 01:44 PM
