Classic Hondas All Pre-1988 Hondas.
1986 honda civic si 1500 1.5 ecu
Old 04-09-2012, 05:20 PM
powerman5000's Avatar
Default 1986 honda civic si 1500 1.5 ecu
Bought car recently. The guy said it was stock but the 1986 honda civic si 1500 1.5 was put in. The car runs funny and he said it needed the non Cal emmissions ECU. Does any of this make sense? Thanks in advance.
Old 04-09-2012, 05:31 PM
garyhibdon's Avatar
Default Re: 1986 honda civic si 1500 1.5 ecu
cali emissions means it has an egr system. check to make sure that its not clogged up, or that its there at all. i may be wrong, but i dont believe the ecu has anything to do with the egr system so id say check that its complete.If its not, make sure there are no leaks and with it being that old you may consider making sure that the carb is functioning properly and that the vacuum routing is correct.
Old 04-10-2012, 04:09 PM
forgive me but i think you misread the info ,it is a 1986 honda but it has a 1986 feul injected 1.5 engine my friend i bought it from switched the motor ,he told me when the car stumbles and idles erraticllay that it is because it needs a non cali emissions ecu because when the motor was changed he did not put in a catalytic converter or any smog devices it still passes smog but it does not run right can anyone help me please,thank you in advance
Newhondabuyer
05-07-2016 03:40 AM
allmotaR
Northwest (Sales)
12-01-2007 10:20 AM
IGGY
12
10-26-2006 04:02 PM
stockegsix
15
08-03-2005 02:11 PM
4g4me
06-04-2003 11:39 AM
Quick Reply: 1986 honda civic si 1500 1.5 ecu
