E-Brake light stuck on?
Hey guys.
So my E-Brake light has been stuck on since I picked up my car, and no matter what I do to the handle, the light stays on. If the e-brake worked at all, I'd be a little more concerned, but even though it doesn't, the light still bothers me. Any ideas?
Re: E-Brake light stuck on?
As everybody else stated, check fluid. The brake light is not just for E-Brake. If your fluid is low, then either your brakes are worn down to a level that may need replaced, or you may have a fluid leak.
The light is there to let you know that you have a problem somewhere in the brake system.
I'm gonna guess the cable is stretched. I found 4 brand new brake pads in the trunk, so I'm gonna throw those on, and give the whole system a once over
Project91CRX
14
04-26-2004 03:47 PM
