Sleeved h2b turbo swap into 87 crx build....
Just bought an 87 hf crx suuuuper clean for 400$
Guy just gave up on the car.
It has/had till today......
Place racing bseries swap mounts
Hasport swap axles
Custom shift linkage for b swap
B16 cable trans on b18a short block gsr pistons std bore (knocking) yay! Lol
Act maxx xtreme clutch 4puck unsprung w fidanza flywheel.
Has 3 i think gallon cell aeromotive a-1000 pump -10 lines filter etc.
Its gutted just drivers seat. Guy said it went 11.7 with stock b16 head and 50 shot.
Anyway i pulled the bad ls block/trans out
Bolting b16 trans to my hlong block tmw.
Im cutting upper and lower radiator support on car and square tubing it further out on bottom for downpipe clearance.
Onto the build...
H22a4 darton wet sleeved scat crank eagle rods je 9:1's arp mainstuds
Arp headstuds ferrea .5mm over valves type s cams supertech s and rs
Venom style obx crap rewelded manifold golden eagle rail id 1000cc injectors
Peakboost tubular mani power master super t70r chinese turbo tial 38mm wastegate tgi 3" downpipe QUARTERSPORT h2b ef kit act maxx xtreme clutch fidanza flywheel hondata s300j. Using the stock chassis wiring for lights and signals then splicing in ek subharness 99/00 w ef fusepanel for engine w rywire jumper harness. Anyone know how to post pics? Also im doing 03 civic hybrid cluster in a dc dash corbeau racing seat ds and crx si 2g pass. Hoping around 17-1800lbs with me in it.
Hoping this is faster than my 89 crx dx built b20 eagle rods crank wiseco pistons fully built crane ls/b20 head stage 3 turbo cams vic x custom top mount w precision 6776rs dual bb turbo tial mvr tial q bov precision fmic 3.25" dp etc injector dynamics 1000's walbro 400 this one is kinda show and go jdm zc hood legit spoon cam gears greddy tbelt toda flywheel hasports etc
Hasport swap axles
Onto the build...
Re: Sleeved h2b turbo swap into 87 crx build....
here's a link to how to post up pic's
https://honda-tech.com/forums/showthread.php?t=3032699
Pics are here more to come!
http://m1267.photobucket.com/albums/...PRA6R61Za84%3D
88crxvtec
11-29-2008 02:13 PM
RyanA
01-21-2007 07:24 PM
