Classic Hondas All Pre-1988 Hondas.
Battery terminal colors
Old 08-23-2017, 05:24 PM
Default Battery terminal colors
1989 Honda Accord LX. I have a brown wire and black wire for my battery terminals. Which one is positive? Thanks
TravisM1331 is offline
Old 08-23-2017, 10:57 PM
Default Re: Battery terminal colors
normally black and green are going to be ground for auto purposes, normally the ground(negative) wire will be attached to the chassis(the body at a metal spot nearby) as well, that's the normal giveaway, and it tends to be on the chassis side as well, while the positive cable will be near the inside of the engine bay
holmesnmanny is offline
Old 08-26-2017, 03:51 AM
Too lazy to go outside and look at my 89 LXi,. Pretty sure the brown - single wire - is the ground, follow the other end to the chassis and then to the trans/engine . The black and white wires are positive, positive should have two wires - one to the fuse box (white) and the other to the starter (black).
poorman212 is offline
Han Solo
06-14-2006 02:31 AM
crex23
16
02-28-2003 02:29 PM
moridin2004
Audio / Security / Video
02-11-2003 10:01 PM
94TealGSR
11-08-2002 11:36 AM
wannab20hatch
10-12-2002 10:15 AM
Quick Reply: Battery terminal colors
  • Ask a Question
Question Title:
Description:
