3rd gen civic dx reliability questions - Honda-Tech - Honda Forum Discussion
Classic Hondas All Pre-1988 Hondas.
Old 01-10-2019, 08:51 AM
Default 3rd gen civic dx reliability questions
Well I am interested in buying a clean 3rd gen civic hatchback dx. It’s either an ‘86 or ‘87 I believe. It’s a manual, I’m guessing a 4 speed, 130k miles, all original. My friend said that 130k is a lot of miles for those years, but I’ve been interested in 3rd and 4th gen civic hatchbacks and 1st gen crx’s for a while and never heard anything negative about them concerning reliability. Any thoughts or advice will be appreciated. Thanks.
RGhonda is offline
Old 01-10-2019, 07:37 PM
zippyPDX's Avatar
Default Re: 3rd gen civic dx reliability questions
I can't help you with your question, but let's see some pictures of this potential vehicle!
zippyPDX is offline
Old 01-10-2019, 07:46 PM
RGhonda is offline
Old 01-10-2019, 09:18 PM
RGhonda is offline
Old 01-10-2019, 09:19 PM
It isnít letting me post the pictures for some reason? It says my post will not be visible till a moderator does approves it or something like that.
RGhonda is offline
Old 01-10-2019, 09:22 PM
zippyPDX's Avatar
Probably be approved by tomorrow.
zippyPDX is offline
Old 01-10-2019, 09:24 PM
Sounds good, and thanks for the replies.
RGhonda is offline
Old 01-11-2019, 04:29 AM
dilbeckskate's Avatar
The 3rd gen civic is great but the base dx d15 carbd model brings you all the issues of driving a classic vehicle, prob needs carb rebuilt or upgrade (weber 32/36) and a vac delete , those cars are cool with dohc dseries
dilbeckskate is offline
Old 01-11-2019, 07:44 AM
Iím 17, would it be a good car to learn on and would it be ok to daily drive? The guy says it runs good. Also, is 130k really a lot of miles for a 3rd gen? Iíve heard of 1st gen crxís going above 300k and I believe that they are pretty much exactly the same as the 3rd gen civics. Thanks.
RGhonda is offline
Old 01-11-2019, 09:09 AM
Blue-Civic-Hybrid's Avatar
As a potential young gearhead, always remember when you buy an older car there is a very high potential for that car to break down and leave you stranded. To learn on, this will be a great introduction for you. As a daily driver, just be prepared to be on your parents AAA insurance for that free sweet towing for your inevitable breakdown.
If you can get the car for $500 to $1000, I say go for it as long as it's just as the seller says it is. Runs good, no electrical issues, not rusty, etc...
Post pics if you can...
Blue-Civic-Hybrid is offline
Old 01-11-2019, 09:35 AM
Yep my family has AAA. In California so rust shouldn't be a huge issue. It's up for $2500 I was thinking about asking if he'd take $1500... I could just throw $1000 out there and see if he takes it, not sure how firm he is on the price. I'll try to post some pics again. Thanks for the advice and helping me understand the reality of daily driving a 35ish yr old car... I'll keep that in mind.
RGhonda is offline
Old 01-11-2019, 09:38 AM
RGhonda is offline
Old 01-11-2019, 09:39 AM
There we go.
RGhonda is offline
Old 01-11-2019, 11:23 AM
very nice
Old 01-11-2019, 01:08 PM
zippyPDX's Avatar
Noice!! Iíd drive it.
zippyPDX is offline
Old 01-11-2019, 02:35 PM
as mentioned before its going to be a fun car and a great learning project , same not it IS GOING TO BREAK DOWN , IS GOING TO NEED WORKED ON , IS GOING TO NEED MAINTENANCE BEFORE DAILY DRIVING , and im sure if you took it to a mechanic to do a inspection they can give you a small novel of worn out parts on it that need to be replaced, id buy it if its cheap and dont have to drive it every day
Old 01-11-2019, 04:06 PM
zippyPDX's Avatar
My experience is that a lot of parts are available and cheap, even for my 83. Unlike new cars you can pop the hood and identify everything and get to most of it easily. Like others have said if you yearn to work on cars, might be a fun thing to do. I drove a series of $1500 cars: a Chevette, a Citation, then the Civic (which I can’t seem to get rid of). I had good luck with all of them. But YMMV.
zippyPDX is offline
Old 01-14-2019, 10:15 PM
Welcome, so you are in Cal, remember that the seller MUST do a smog check before selling the vehicle.... the smog check data will give you good infos of the general conditon of the engine. Be aware that the 3rd gen engines are lean burn engine and the level of NOX gases are usually fairly high due to lean burn and there is really no way to adjust it... if it is a carb model... I have an 86 vintage with the carb , 1500 cc engine and 5 speed, really a blast to drive, even at 175Kmiles. Owned for the last 7 years and 45Kmiles. I had very high Nox and found it to be a loose hose below the intake manifold, but it still cost me a misdiagnosis by the smog tech that said that a new cat had to be installed, which was not needed. I never rebuilt the carb, which is not really recommended because the insulator between the carb and intake manifold was unobtainum. Check redpepperracing for more tech infos...
What has been done, new coil, new radiator, the distributor internal seal was replaced due to leaky engine oil inside the distributor, alternator, starter, battery, spark plug wires, better shocks? I found a completed AC system at the junk yard that was still holding refrigerant and installed it, One of the vacuum switch has failed so the cold morning start are still good, but after a few minutes on cold California days the engine may stall and be hard to restart.... but with a manual trans, pop it in 3rd gear and let it roll...
$2500 is a bit steep, $1500 is a good price, the state will give the owner $1000 if they retire/donate the car at the local junkyard.... which do not see too many of this year vintage... The car looks good, except that you need a new driver seat and those are not cheap... make sure that all electric accessories work, radio, rear wiper and rear defroster... I had to repair the rear electrical harness that had some broken wire by the hatchback tailgate... remove the trunk cover and check for water puddle, there should not be any water....
Cheers
letank is offline
Old 01-15-2019, 06:02 AM
Cheers
Listen to this guy... buyer beware...
Old 01-15-2019, 07:16 AM
also on top of it as mentioned before this isnt going to be a car you troublefree drive for a extended period of time, if you arent comfortable with finding worn out parts or diagnosing noises/problems take it to pretty much any mechanic for a $50 used car inspection and generally speaking you will be able to use that to influence the price where you want it and the $50 saves you sometimes hundreds
Old 01-15-2019, 10:14 AM
Thanks for the replies guys. The guy doesnít say much about the car in the description, just that it is all stock, 130k miles, new tires, stick shift. Also, it is 2 hours or so away from where I live so it may be a little hard to get my parents on board, especially at the moment. I may have to take a pass for now, Iíll save his number and maybe when things settle a bit Iíll see if he still has it, or just wait for an EF to come up since those would be more daily driveable and easier to find parts for, although to be honest that would make me kind of sad since I love the old-school civics. Weíll see how it goes. Thanks for all the advice, you guys are really helpful.
Iíll be back for sure.
RGhonda is offline
Old 01-15-2019, 10:16 AM
oh.... I thought this was like you bought it or it was local ersumshit #wasteourtime2019
Old 01-15-2019, 10:27 AM
I didnít mean to waste anyoneís time, I can still use the information even if I donít end up with the exact car, youíve given me some useful knowledge that I didnít have before and couldnít find anywhere else, and others can use the info on this thread as well, itís not just for me. Sorry if thatís the way you feel.
RGhonda is offline
Old 01-15-2019, 01:36 PM
im just talking **** dude , I was hoping you got the car soo somebody on here would have a dope *** 3rd gen
Old 01-15-2019, 02:28 PM
I hear you... Iím going to get in touch with the guy, Iíll just have to find a day that my dad can take me out there, and weíll also have to work some insurance stuff out as well...today my family found out that our insurance is raising their rates, it would be $200 a month just to add me as a driver to the policy, and that isnít even the car. 😕 Seeing as I would be paying my own insurance Iím not sure if I could swing that...
RGhonda is offline
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
Question Title:
Description:
