Classic Hondas All Pre-1988 Hondas.
1978 cvcc hatchback build
Old 03-29-2017, 08:29 AM
Default 1978 cvcc hatchback build
we got a 1978 civic hatchback cvcc with 1.5liter motor
taking the engine apart
what would be some things to do while rebuilding
is it possible to put a small turbo or supercharger on this
we try to make it a mini civic type-r but chose not to replace the original motor with a boosted single cam
so if possible turbo on original motor
fuzzysig is offline
Old 03-30-2017, 04:20 AM
DA BOSS's Avatar
Default Re: 1978 cvcc hatchback build
Do yourself a favor and swap in a D16Z6 since you're going through the trouble. You'll be getting a MUCH more modern platform to work from that has gobs of aftermarket support - and stronger components that can handle the turbo later.
If you do decide to boost it - you're gonna need an aftermarket blow-thru carb setup (or modify factory carb... pretty expensive either way), supplimental fuel (one idea is to power an additional injector based on rpm w/ something cheap like Megasquirt)... and a way to tune it all. All of these issues have been solved before (you'll no doubt end up on the Buick GN boards for tech) with the EB series motors... but my suggestion is to do yourself a favor and go D16Z6.
DA BOSS is offline
Old 03-30-2017, 06:56 PM
Blue-Civic-Hybrid's Avatar
What he said up there...
Blue-Civic-Hybrid is offline
Old 03-31-2017, 10:04 AM
how much cutting do I have to do for d series?
I don't want to cut up the frame to fit a motor in it. this is the original 1.5l cvcc 5 speed hatch the original motor still good just needs new gaskets etc
fuzzysig is offline
Old 03-31-2017, 02:20 PM
is there a fuel injected engine that is a direct swap into it?
fuzzysig is offline
Old 03-31-2017, 04:06 PM
Full_Tilt's Avatar
A d-series swap is going to require custom mounts. I think the axles may work between a 1st gen E series and a D series, but Im not 100% sure. It has been done before though. Get to googlin'.
You may want to consider finding an EK 1.8L engine out of an old accord/prelude. Should be a direct swap as it is just a bigger displacement E series engine.
Im not sure if you will be able to use any factory Honda EFI intake manifold on a CVCC E-series. The later E series like the EWs found in 1st gen CRXs didnt have CVCC.
Full_Tilt is offline
Old 04-01-2017, 12:08 PM
music to my ears lol
what about transmission?
are those accord prelude transmissions would work in the civic? or bolt on to the stock 5 speed civic transmission?
i never even looked into this . i like b series and know a lot about those snd some d series but not this
any old guys that done it can help me out with just random questions picking their brain i have been googling but the info it hidden on bunch of random tiny webpages here and there unlike b series
I'm finding small bits of info scattered all around
fuzzysig is offline
Old 03-06-2018, 09:03 PM
[QUOTE=fuzzysig;51245098]music to my ears lol
I'm finding small bits of info scattered all around[/QUOTE
There is a lot of cutting required to do a b swap. I have some pics I can upload soon of a 78 I am working on putting a supercharged itr into. Also I have a factory 1.5 that came out with only 70k if someone needs it.
Adam Williams is offline
  • Ask a Question
Question Title:
Description:
