86 civic dx d16a1 swap questions
Hello I have a 86 civic hatchback and a d16a1 motor. Ive been looking all over for info on the swap especially for the fuel system conversion and for the wiring and hub assembly. As of right now I got a knuckle and bearing for it. Idk if I can just press them in to the hub assembly or I have to get the hub assembly from a 86-89 integra.
I also been seeing that I need to get fuel lines from a crx si. But I havent been able to find it a I was wondering if there would be another alternative like using a universal fuel line or run breaded fuel lines all the way from the pump to the fuel rail and if so where do I find such a part. A la what kind of fuel pump and fuel pump bracket so I use? And for wiring I just don' know where to start I don' even know what kind of harness I got it what kind I need it what ecu do I need to run. I just need some solid info or a solid guide to help me through this swap I've searched in redpepperracing but they weren't much help. Please help. I really need it.
Re: 86 civic dx d16a1 swap questions
Also I got a jdm obd0 b16 and everything from my da integra so I was wondering if that'l be any easier or more worth the swap then the d16a1? If i can a also get a swap guide on that too then that'l also be great
boostedblue23
10-04-2017 05:38 PM
