negative camber fix???
1991 wagovan. Dropped 4 inches in the rear. Car obviously has negative camber, what's the easiest way to get back to stock stance? Will aftermarket lca's fix my camber issue? New to the honda game, please help!
Re: negative camber fix???
ok, first of all, are you raising the car back up? you said back to "stock stance"
if so, then the camber issue should correct itsself. if you are staying low and wanting to correct the camber, then there are proper parts for that. do your research, its very simple.
Not raising it back up, just want 0 camber. Sorry for the confusion. So basically I slammed the rear of the car and it has negative camber. How do i go about getting it back to 0 camber?
I've read nothing about bad reviews about camber kits... just replace lca's and it didn't get any better. alot of people said bushings but obviously that didn't help any other idea's or suggestions, or do you have any experience with camber kits?
darkknightwong
11
09-18-2002 09:41 AM
