1983 Honda Accord will not start.
First off, I do not know a lot about cars so please try to explain everything as thoroughly as possible. I have an 83 accord, and the first time I try to start it after it has sat for a while, it starts up fine but will stall if I take my foot off the gas. After it stalls I can not get it to start back up again.
Originally when i had first got the car it would almost never start and i noticed that the carb was loose and could be jiggled from side to side. I set about fixing that and with my very limited experience i managed to remove the carb and found six screws that i assume held the thing together, 3 of which were so loose that were slightly tilting the carb and allowing it to jiggle. Now that everyhting is put back together that leads to where i am now.
Through a little bit of research i think it might be something to do with the fuel pump or some related part. Please help if you can.
Re: 1983 Honda Accord will not start.
As an aside, if you construct a pigtail with spade connectors, you can jump the two top slots that the fuel pump relay plugs into just above the fuse block. (you might check the fuse as well).
If the fuse is good, the pigtail is plugged in and the fuel pump runs, then the enable circuit is not complete between the relay and distributor.
Get a shop manual of eBay...
Osito9971
04-01-2018 04:23 PM
Casey Lewis
01-27-2016 01:40 AM
