Go Back  Honda-Tech - Honda Forum Discussion > Honda and Acura Model-Specific Technical Forums > Classic Hondas
Reload this Page >
89 Honda Accord LXi Engine Code 6 not fixed by ETC sensor, sending unit or switch
Classic Hondas All Pre-1988 Hondas.
Old 01-11-2018, 11:24 AM
Default 89 Honda Accord LXi Engine Code 6 not fixed by ETC sensor, sending unit or switch
Hi all, first time posting on here. Here goes nothin. Bought an 89 Accord sedan LXi. Engine code 6 led blinks on ECU. CEL used to be on all time with hard start. Changed out ETC after finding another post about the light blinks and diagnosing, etc. Now starts right up, gets up to temp and idles fine without CEL coming on. Drive for 1.5 mins and boom, on comes CEL with same 6 blinks. Replaced the temp sending unit next, temp reading same. no change to CEL status (off at start, comes on when driving). Replaced the radiator cooling fan switch and it came on great the first startup, now fan does not come on. no blown fuses. IDK what to do next. It doesnt overheat, only problem now is that the battery light comes on. Help would be appreciated. TIA!
TJ
Thomas Lilley is offline
Old 01-11-2018, 12:52 PM
Default Re: 89 Honda Accord LXi Engine Code 6 not fixed by ETC sensor, sending unit or switch
https://www.hondapartscheap.com/auto...er=37750ph2014
what parts did you replace ?
it's possible the ecu is bad if the wiring is known to be good
holmesnmanny is offline
Old 01-11-2018, 02:58 PM
The engine temperature control sensor, the temperature sending unit and the cooling fan switch for the radiator. Not 100% on wiring for the ETC sensor or cooling fan. I assume the ETC is good because light used to come on at start and stay on but now it doesnt come on until the engine is up to temperatire and driven for about a minute.
vtecpoweredsol
11-06-2009 11:54 AM
Jack42038
12-28-2008 08:32 PM
ImThatGuy
11-15-2004 08:55 PM
Quick Reply: 89 Honda Accord LXi Engine Code 6 not fixed by ETC sensor, sending unit or switch
  • Ask a Question
Question Title:
Description:
