Classic Hondas All Pre-1988 Hondas.
"Christine the evil 84 crx build"
Old 04-12-2015, 05:46 AM
Default "Christine the evil 84 crx build"
Well first off bought this 84 crx d15a1 carbureted powered 5 speed crx Had nothing but bad luck out of the car spent money for a webber kit to only find the engine has a horrible knock. well decided to ditch the d15a1 with its little five speed transmission and build something that is truly different, I bought a 1995 Honda accord f22b1 vtec automatic car. i wanna take its drivetrain and stick over into this shell. I know the innovative swap mounts is needed and all the wiring harnesse is needed out of the accord, I know the d15a1 comes out with a whoping 67hp, well this engine i want to put in is a vtec f22b1 witch comes out factory 145hp with 147ft lb of torque, this is a racecar not a street car. i wanna do this swap simply because i have the donor car and the engine that is inside of this car isn't worth using any longer. thanks in advance..
TheRookie74 is offline
Old 04-14-2015, 12:43 PM
3gcvcd16's Avatar
Default Re: "Christine the evil 84 crx build"
there are no mount kits available for this swap you have to make your own, as for the tranny get a manual tranny and use the accord harness just cut what is not needed
3gcvcd16 is offline
Old 04-14-2015, 06:45 PM
thought I may be able to use a 89-91 mount kit from the innovation mount company "Swapshop racing"
sheBangZ
Appearance Build Threads
282
02-01-2018 01:03 PM
dual_turbo30
08-22-2017 06:29 AM
FunnyVictor86
02-23-2017 10:06 PM
GreatWave
12-02-2016 06:49 PM
TheRookie74
09-15-2015 12:52 PM
Quick Reply: "Christine the evil 84 crx build"
  • Ask a Question
Question Title:
Description:
