3rd gen civic b18 swap need help !!
Hello i have a ek3 b18c in nitrous for dragracing now i always have a weak for the 3rd gen .
So now i want to build everythink from the ek to the 3rd gen
What do i have to buy
I know i need to buy motormouts hydro kit from hasport
Im going to build mij ek pedals in to make it hydro like the new models .
And i read that i must buy axles .
Cant i use other axles or somthink and what kind of T bracket do i have to use ( EK EG ED )
and can i use my ek shifter i cant find the right name my english is not so good but hope you guys no what i am.saying .
For the test im going to use the hol ek electrical system
Thanx mike
Thanx mike
Re: 3rd gen civic b18 swap need help !!
hasport mount and axles
oem b16 ek t bracket.
custom shift linkage. use old and new weld together... some say 1g teg linkage works..
DA half shaft with SK7 stamp
obd0-obd1 ecu jumper harness..
jumper for distributor
chipped obd1 ecu remove vss to use stock cluster
search redpepper! good luck
BiGcAmBoDiAnSaUsAgE
10-15-2006 07:16 AM
Punker1234
03-04-2005 01:24 PM
