Limited slip conversion
So, I was looking around for diffs on ebay, and I found this.
http://www.ebay.com/itm/250915233189
How does that work?
How does that work?
It looks more like it would make a locked diff than a limited slip.....
How exactly does that gadget work? Cause it doesn't make it a mechanical, clutch, or fluid limited slip....
The premise is that the gears are pushed apart against the casing so it works like a clutch-type LSD. Doesn't work without the clutch plates though (but like I said, Bone knows a company that will turn a stock diff into a clutch-type LSD, the works similar to how the linked one should).
goforbroke
Jul 12, 2004 07:27 PM
