Transmission & Drivetrain Gearboxes, Differentials, Clutches
s4c ctr trans issue
Old Jan 13, 2013 | 12:53 PM
Jdmefsir12's Avatar
Default s4c ctr trans issue
s4c helical lsd ctr trans:
i have a 6 puck clutch sprung stock b series pressure plate and flywheel
my issue is when i am driving and from time to time i go into third and it will push it out... and other times it will go in smooth no issues.... and also in morning time when i start driving i go into third it will kick me out instantly... and at high rev i can go to scond or third but if i am at high rev and i baby it in will go in no issue...
hope i explained it right...
could it be stock pressure plate???
could it be bad syncros?
info and input would be awsome thanks
Old Jan 13, 2013 | 01:14 PM
Jdmefsir12's Avatar
Default Re: s4c ctr trans issue
ttt
Old Jan 13, 2013 | 01:55 PM
MRGRIM's Avatar
R.I.P. Mark
thats not from the clutch at all
your right that is going to be syncro's
time to put a full rebuild kit through it
" Bearings Syncro's Seals"
and you might want to think about an LS 5th gear while your in there
to lower your revs in top while cruising
Im about to do the same thing as my input bearing is going out
Old Jan 13, 2013 | 02:11 PM
Jdmefsir12's Avatar
oh ok and how much does a kit like that go for cuz i had the syncros redone and there are all carbon coated
Old Jan 13, 2013 | 03:12 PM
MRGRIM's Avatar
R.I.P. Mark
not sure how much it would cost you as Im in Australia
but its going to cost me $800 US for full kit bearings syncro's and seals
Old Jan 13, 2013 | 06:44 PM
Jdmefsir12's Avatar
Damn thas a lot that's like a new transmission lol
Old Jan 13, 2013 | 06:45 PM
Fliptard's Avatar
who did you syncros? how long ago? I would take it back to them and tell them your having issues with it and make them fix it.
Old Jan 14, 2013 | 12:48 PM
Aquafina's Avatar
Synchro spring, dog teeth, slider teeth, shift fork (contact or detent), SCA, SCHA, clutch/pressure plate, CMC, CSC, etc.
What all have you checked so far on it?
Old Jan 16, 2013 | 09:06 AM
Jdmefsir12's Avatar
lol just the pressure plate shift linkage trans oil bushings thats it right now... havent pulled it aprt yet.. but i will
Old Jan 16, 2013 | 04:47 PM
yungmulacrx's Avatar
What kind of fluid you running?
Old Jan 21, 2013 | 10:36 AM
Jdmefsir12's Avatar
lucas gear oil..
Old Jan 21, 2013 | 07:06 PM
Aquafina's Avatar
Get rid of it.
Supertech 10w-30, Torco MTF, or Torco RTF.
Old Jan 27, 2013 | 07:12 PM
Have you changed the gear oil yet? How cold is it where you live?
Jmp95EG
Jul 2, 2014 10:29 AM
Clerique
Sep 6, 2010 12:48 PM
B16B_coupe
Aug 13, 2006 10:57 PM
H22ACiViC
Mar 16, 2002 04:12 PM
