Transmission & Drivetrain Gearboxes, Differentials, Clutches
Reverse gear issues
Old Jan 3, 2013 | 03:44 PM
spotrep's Avatar
Default Reverse gear issues
Mainshaft and countershaft are now successfully installed. Inevitably, I ran into another problem. The reverse gear doesn't seem to be engaging when we put the linkage into reverse, is this because the transmission is vertical when it is normally horizontal, or am I missing something?
Old Jan 3, 2013 | 08:13 PM
MR.johnson's Avatar
Default Re: Reverse gear issues
Spin the main shaft slow with pressure going into reverse. If it doesn't go in you have an issue.
Old Jan 12, 2013 | 09:24 AM
93h2beg's Avatar
you could always post up a pic or two. if something is glaringly wrong we could let u know.
Old Jan 12, 2013 | 02:07 PM
Aquafina's Avatar
Put the case on and seat the snap ring, use a couple of bolts to secure it, then try benchshifting.
corpsebesideme
Jan 8, 2018 01:40 PM
kdsmonitor
13
Oct 10, 2008 07:16 PM
94turboeg
Jun 13, 2007 02:43 AM
ekcoupe88
Honda Civic (2006 - 2015)
16
Apr 26, 2007 09:05 AM
not so civic
Jun 18, 2003 09:07 PM
