PDA
View Full Version : Lighting
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13]
  1. Help! What kind of bulbs are these???
  2. EJ8 Turn Signal Socket
  3. replacing hid bulb
  4. Retrofit ????
  5. Any bulbs out there that look even close to HIDs?
  6. hids? where to get them
  7. what kind of bulbs for em2
  8. HID hELP..
  9. Dimmer Switch Bypass?
  10. amber city lights? help me out
  11. Electrical problems inside 94 Integra Advice???
  12. HID's?
  13. 92-95 EG Projector Headlights
  14. 75$ ebay HID kit review
  15. Will foglights from EG hatches fit into EG 4 doors?
  16. JDM ITR HID!!! i need some HELP ASAP
  17. G35 Projector?
  18. aiming hids on integra
  19. new headlights changing bulbs
  20. dim turn signal
  21. Need help with electrical problem for lighting
  22. EK JDM Amber Side Markers
  23. 1994 civic headlight suggestions/help
  24. How can you tell if Vision Amber Corners are authentic?
  25. what is the difference between D2C, D2R and D2S bulbs?
  26. NEED HELP WITH HIDS
  27. 98-02 ANGEL EYES HEAD LIGHTS?? BULB SIZE??
  28. Anyone tried the new Osram headlights
  29. HID style bulbs.
  30. how to SMOKED tail lights
  31. Turn Signal Not Working HELP!
  32. head lights for jdm itr headlights
  33. are u guys running HIDs or light bulbs?
  34. Ebay projector Headlights VS Retro fitted projector headlight
  35. DA JDM Headlights...what bulbs do they take.
  36. depot ek foglight bulb?
  37. HID kit for CD
  38. 99-00 Civic Retrofit.
  39. HID installation
  40. sylvania silverstar ULTRA
  41. can you hard wire eg6 foglights ???? to run either when lights come on or all the time???
  42. im looking for S2K PROJECTORS
  43. OEM fog lights wiring NEED HELP WILL PAY$$!! LONG BEACH CA!
  44. Parking lights stay on, 94 Accord
  45. Another HID question?
  46. have some questions
  47. What brand of PnP HID kit?
  48. Aftermarket 98+ Integra headlight
  49. Question for Certified mechanics, and Engineers!
  50. Ek fog lights in an Integra
  51. high beams, but no low beams
  52. One headlight works, one doesn't?
  53. HID question or thoughts
  54. anyone know how to do this?
  55. Headlight Turn Signal Bulb Question.!!
  56. Bi-Xenon Kit
  57. Toshiba Infrared Reflecting bulbs
  58. Lense reconditioning.
  59. 96-98 headlight Questions
  60. Toshiba HIR
  61. Looking for the brightest Light bulb out there(none HID)
  62. HID kit into my 91 hatch...all the right stuff just wont work
  63. D2S Projectors Can i use Any Hid Kit
  64. Help on Brake light and a few questions
  65. Brake Oil on Headlights
  66. How-To: Acura TL HIDs into any JDM H4H headlamp
  67. HID KIT PROBLEM?
  68. One side works other side doesn't?
  69. running light issue
  70. Should i get 5000k or 6000k HID
  71. adjust 99 civic headlights?
  72. ANY BODY ROCKN THE EDM REAR FOG LIGHT ON THEIR DC2? HELP
  73. HID radio interference?
  74. whats brightest bulb that i can use in my gauge cluster???
  75. moding an h4 bulb to fit in 1 piece headlights that require h4h bulbs for HIDS?
  76. Mismatched HID's
  77. Fast blinking turn signals in 94 Accord
  78. What is the part number?? For...
  79. Hid Shield H4(anyone)
  80. Brighter headlights on a DA? Also, fog light question.
  81. rewiring high beam to a low beam switch ...help!!
  82. help with tyc headlights
  83. ~50W to 80W draw?
  84. REPLACING FOG LIGHT BULB
  85. 4300k vs 6000k?
  86. Are there any fog lights that take up the whole space in a 05 Honda Accord?
  87. side markers
  88. possible to remove the ghey halos?
  89. whats the most i should pay??????
  90. retro hid
  91. JDM DC5 sidemarkers
  92. little help here please.
  93. New HID setup
  94. installing side markers
  95. HID KIT ???
  96. Tint on your headlights/taillights
  97. my left sign is out aftyer i installed ek9 fog lights
  98. Integra Fog Lights
  99. e46 wire harness diagram?
  100. Halo's
  101. prelude tail light
  102. need help with some side markers here
  103. noob question
  104. Silverstars
  105. 96-98 fog light relay keeps messing up?!
  106. Need help changing front sidemarker bulbs
  107. WHERE WOULD IT BEST TO PLACE MY STREETGLOW KIT?
  108. HIDs In My 98 Civic
  109. HID ballast mounted on integra
  110. headlight bulb
  111. H4 to H7 Conversion
  112. trailer lights
  113. EG headlight disassembly and retrofit question
  114. What foglights are good
  115. HID retrofit questions....
  116. XENON H.I.D KITS 160.00
  117. TAIL LIGHT PROBLEM
  118. Change Full Headlights In My 2000 Civic LX
  119. diy headlights
  120. headlight for 08 civic
  121. brake lights dont work
  122. HIds
  123. HID Swap into my Lexus ES300 Projector
  124. where to put ballast
  125. What does you jdm headlights look like at night ?
  126. hids into a civic???
  127. 97 accord CD5/CD6 front end re-wiring question (need help)
  128. Eyebrow / Eyelid - 96 Civic
  129. grounding my ballast
  130. Fog Light Wiring
  131. How to turn foglights yellow?
  132. The art of great service: 3BSPEC.com!
  133. HID install problem on JDM ITR headlights
  134. H4 Civic HID Help
  135. CA - Yellow Headlamps
  136. wiring diagram
  137. ***OFFICIAL: Post your HID retrofit cutoff pics***
  138. running lights fuse problem
  139. Can I retrofit IS300 Fog light projectors in my 99-00 Civic Fog lights?
  140. Do maxima projectors work well in 99-00 civic head lights?
  141. 97 DC TSX projectors
  142. trunk Light In - 1996 Civic LX
  143. HID bulb went out
  144. my headlight fuse keeps blowing!
  145. Foglights no working (on a DA)
  146. hid problem
  147. Which HID System?
  148. hid kit.. high beams dont work..?
  149. CRX headlight to eg
  150. Correct way to wire JDM sidemarkers? (96-00)
  151. one piece headlight DA question.
  152. Changing Headlight bulbs in a 1996 Civic LX
  153. jdm one piece head lights on DA
  154. why would low beams not be working, but the high beams are???
  155. What are xenon headlights?
  156. *PLEASE VOTE* - Interest in a "Lighting" forum?
  157. install HID kid...into my Civic...HELP
  158. del sol retrofit hid
  159. HID.
  160. need help with banbo hid lights
  161. HID issues
  162. hid's...
  163. **HID LowBeam+HiBeam --- Discussion -- Bump IfYou Look**
  164. Lighting experts needed: bulb fixture question
  165. hid bulbs??
  166. NEED HELP WIRING JDM NON HID HEADLIGHTS
  167. New to hid
  168. post pics of your hid set up with stock headlight housings or foglights
  169. JDM ITR HID Headlights - What ballasts/igniter?
  170. 97 Accord lighting questions
  171. Simple lighting question
  172. HID Retrofit Advice
  173. How to install aftermarket HID kit in one picture.
  174. HID
  175. Ok TYC 1 piece projectors with HID kit for EG's Pics
  176. OEM vs. Nighthawk vs. X-Treme +80%: The Showdown <56K Intense>
  177. Calling on JDM front DC2'ers...
  178. REF: Automotive Lighting, Color, and You
  179. HIDs in a DA?
  180. HID retrofit club
  181. Hid in 99-00 ek foglights?
