Lighting HID/Xenon kits, Retrofits and Associated Topics
HID install problem on JDM ITR headlights
Old Sep 12, 2007 | 03:35 PM
ITR32's Avatar
Default HID install problem on JDM ITR headlights
I have a ITR JDM front and got a set of aftermarket HIDs for now retrofit on the way. My question is the HID ballast (9006) line up with my sockets for the bulb but cant get them to rotate to lock them into place. Is there anyone else who had this problem Ive searched on it cant find anyone.
Old Sep 12, 2007 | 04:28 PM
Crx Jimmy's Avatar
Default Re: HID install problem on JDM ITR headlights (ITR32)
If you are trying to put the stock 9006 sockets onto the ballast I had to grind a notch in mine for then to clip on, also the wires on the 9006 plug needed to be swapped, the + and - were on opposite sides on the ballast than on the plug. maybe yours is different I was using hella ballasts in a crx
Old Sep 12, 2007 | 04:51 PM
Genuine Rolla's Avatar
what you actually might have to do is actually take off the bases that come with the kit since i've noticed that a good portion of the time, they dont fit well nor are they able to put the connectors into the OEM harness far enough.
Old Sep 12, 2007 | 05:17 PM
ITR32's Avatar
Default Re: (Genuine Rolla)
Yea thats what it is the base is too big so it wont lock into place. So gring it some worked?
ballinthavx
Feb 25, 2010 11:28 AM
kenzo42
Oct 29, 2008 08:43 PM
ITRtist
Mar 12, 2007 03:53 PM
TheIntegraGuy
Nov 9, 2003 03:38 PM
ILOVEGIRLS
Feb 8, 2003 07:31 PM
