Lighting HID/Xenon kits, Retrofits and Associated Topics
TAIL LIGHT PROBLEM
Old Sep 19, 2007 | 04:12 PM
sh0rd87's Avatar
Default TAIL LIGHT PROBLEM
I just put in si tail lights. All i did was plug them i didnt mess with the wiring at all.
When i press on my brake both of my blinkers come on and stay on until i let go. What can be the problem?
Old Sep 19, 2007 | 04:24 PM
nix94delsol's Avatar
Default Re: TAIL LIGHT PROBLEM (sh0rd87)
not Si tail lights, 99 to 00 tail lights
cut and switch the wires
Old Sep 19, 2007 | 05:02 PM
3lo's Avatar
3lo
maybe you put the bulbs in wronf spots.
see what happens when your emergency lights flashes.
Old Sep 19, 2007 | 05:21 PM
sh0rd87's Avatar
Default Re: (3lo)
the emergency lights flash normal, and the blinters work normal until the brake is pressed then the energency lights are on steady until the brake is off
sh0rd87's Avatar
Default Re: (3lo)
the lights were made for the 96-98 civic
Old Sep 20, 2007 | 02:21 AM
NOFX's Avatar
H-T White Ops
Default Re: (sh0rd87)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sh0rd87 &raquo;</TD></TR><TR><TD CLASS="quote">the lights were made for the 96-98 civic </TD></TR></TABLE>
What?
The lights you say you installed are '99-'00 Civic coupe taillights. They're the same for all USDM '99-'00 Civic coupes (DX, EX, HX, and Si).
The wiring harnesses should look basically the same as your '96-'98 taillight harness, only the turn signal bulb is different.
Old Sep 20, 2007 | 07:26 AM
sh0rd87's Avatar
Default Re: (NOFX)
well the turn signals work unless the brake is pressed then they both stay on until i release the brake , how can i fix that?
Old Sep 20, 2007 | 07:09 PM
sh0rd87's Avatar
bump
Old Sep 20, 2007 | 07:59 PM
Padawan's Avatar
Darth ModerVader
There is no way that what you're describing would occur unless something happened to the wiring when you installed them.
mikeycivic
Mar 11, 2007 02:49 PM
^Sammy]!.
Honda Civic (2001 - 2005)
Oct 10, 2006 06:21 AM
irishbobby23
Sep 13, 2006 06:11 AM
wowowee
Sep 8, 2005 01:32 PM
