PDA
View Full Version : Lighting
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13
  1. del sol lower foglight
  2. dash lighting, help plz.
  3. Seriously Headlight help needed
  4. SPRAYED TINTED TAIL LIGHTS HELP
  5. Strange problem with HID bulb
  6. Eg Cluster lights
  7. Lexus ES300 PRojectors
  8. fog lights/relay
  9. H11 Ballast work with 9006 Bulbs??
  10. side markers jdm db8
  11. Fuse/light issue
  12. 10000k HID Bulbs. Oops.
  13. Electrical problem
  14. weird hid problem
  15. jdm type r HID kit
  16. So if I got these HID lights
  17. need help finding an HID Ballast!!
  18. I NEED HID CONVERSION FOR H4H BULBS!!! PLEASE HELP!!!
  19. Changing bulbs 92-95 fog lights
  20. switch help!!!
  21. Electrical issues................
  22. need help wiring JDM ITR headlights...
  23. 93 civic hatchback light problems
  24. did i just destroy all hope of fixing these?
  25. Help with Electrical problem after retrofit: causing CEL
  26. "Write up"Installing JDM Fog Lights
  27. WIRING TL HIDS QUESTION
  28. Right side Turn Signals dont signal?!
  29. Illegal Headlights????????
  30. Third brake light??
  31. Help Light Bulb #s
  32. HID suggestions
  33. Question about hard wireing an hid kit
  34. Headlight Cleaning
  35. Headlight and Turn Signal Help!
  36. HOW DO I HOOK UP EK4 SIR CITY LIGHTS?
  37. HIDs Causing Honda Computer Problems?
  38. light bulbs help!
  39. acura tl ballasts and bulb questions, as well as audi projector questions!!
  40. bulbs
  41. Broken Foglight Lenses
  42. How can they claim these are street legal?
  43. 93 Accord LX TailLight Smoke Help
  44. NEED HELP
  45. Brake light problem!!EMERGeNCY!!!!
  46. 92-95 Honda Civic Fog Lights Installation???
  47. Infinity FX35 projectors question (retrofit into del sol)
  48. WTB. Turn Signals lights wont work and full voltage on motor.
  49. DOME...haha light!
  50. Worthless ballasts? Toss them?
  51. HID KIT with no Harness
  52. DIY: HID Retrofit in an EK
  53. EG Headlight Question.
  54. PLEASE HELP!
  55. will this setup work?
  56. DIY: LED Climate Control and Brake Light
  57. DIY City lights for civic headlights.
  58. Turn signals not working...
  59. 1994 civic dx hatch under dash fuse guide
  60. DIY: how to clear your cloudy plastic headlights
  61. Adding relay to PnP harness...
  62. S2K Projector Retro Fit
  63. question halo head lamps
  64. Pre Made HID headlights
  65. H4 HID wiring harness....need diagram!
  66. CAR DIES.WEIRD LIGHTING PROBLEM!!
  67. jdm itr fog wiring
  68. Highest Wattage Bulbs For Stock Wiring/Housings
  69. Aftermarket headlights?
  70. 92-95 Honda Civic Fog lights Broken Lens
  71. firewall 06 Civic
  72. New headlights? Help.
  73. South Cali rewiring shops????? BIG wiring problems
  74. Plug and Play Issue
  75. del sol, fog light substitute
  76. HID trouble
  77. passanger side headlight pointing up
  78. good HID kit/headlight combo?
  79. H4-3 ???
  80. How to smoke tail lights?
  81. ej1sidemarkers
  82. H4 wiring diagram
  83. Where to find these EG headlights?
  84. Anyone try those tire valva cap lights?
  85. check out this HID kit and give me your input.
  86. Inspire headlight wiring??
  87. Fix gauge cluster
  88. HIDs problems
  89. How to create a Yellow high beam bucket...
  90. are all ballasts the same?
  91. HID Foglight
  92. Alternative to HIDs.
  93. Fuse for HID kit
  94. help new york state hid laws
  95. What size HID?
  96. Beamers HID help please!!
  97. HID question....
  98. Cursed headlight dilemma
  99. hid on 99 accord
  100. halogen question
  101. Disabeling the day time running lights
  102. OEM ITR PROJECTORS
  103. 35w or 50w ballast
  104. Interior lights??
  105. Bjorn at Customlights
  106. integra fog lights
  107. ITR S2K Retrofit in progress. lots of pics. Advice needed
  108. DIY: EG jdm side marker install (in a hour!)
  109. headlight problem
  110. hid retro?
  111. ITR corner lights problem please help!!!
  112. fog lights for 00 civic coupe
  113. 1992 integra cluster
  114. tail light indicator on guage???
  115. ITR corner lights problem please help!!!
  116. Fog Light Question
  117. amber corner problem
  118. GOOD HID KIT ADVICE PLS
  119. Si-Vtec Corners, Sockets, Signals.
  120. Gear Indicator Light in Gauge Cluster
  121. black housing headlights
  122. Headlight Problems
  123. LMC Headlight Harness for Dodge Rams
  124. HID's in OEM Integra lights
  125. 92-95 civic foglight install
  126. 91 Civic SI Fuse diagram
  127. HID's in OEM Integra lights
  128. lights!!
  129. HID Question
  130. need help install fog lamp kit on 99 civic lx
  131. help one hid is n ot working
  132. fuse keeps blowing out please help
  133. Im not really a fan of JDM but I like some tail lights and headlights ive seen, how do I know if the
  134. What is best solution for improving night vision with halogens or foglights
  135. 00 civic ex aftermarket fogs W/ oem harness
  136. Infividual LED's for front / tail lights, etc.
  137. What wattage are Cuzo light bulbs?
  138. jdm cluster not very brigth
  139. what is the capacity of a car battery?
  140. HID problem, not turning on
  141. DIY LEDs for Stock Cluster
  142. oem lights doenst light up good
  143. HID's Vs. Halogen (06 Accord)
  144. eBay housings and HID PnP kit came with car... what to do?
  145. DB1 fog lights
  146. Looking for help to purchase Fog lamps that are compatible wit HIDs
  147. which kind of bulbs?
  148. 2002 Civic sedan headlight replacement
  149. hids dont light up like hids
  150. what should i do?
  151. silverstar bulb size for del sol...
  152. anyone know how to wire side fogs???? (dc2) cornering/intersection lights
  153. painting the turnsignal reflectors
  154. Acura Integra ONE Headlight not working ... Xentec HID's
  155. Recomended Halogen Headlights
  156. What is the difference between Retro fit & Plug & Play HIDs
  157. Are all D2S bulbs the same?
  158. problem when driver side headlight/turn signal.....need help
  159. HID bulb size
  160. WTB: Retrofitted Eg Headlight
  161. Del Sol Projectors.
  162. HID Bulb Question (Xenon+Halogen)
  163. JDM DC2 Front End Headlight Removal HELP
  164. HID bulb size
  165. slyvina bulbs
  166. JDM Front integra light ??? please help
  167. aftermarket head lights with HID will it work????
  168. Projector OR JDM+HID?
  169. Question about oem style fogs for 93 civic si (EG)
  170. VVME HID kit
  171. Will an HID kit void a factory warranty?
  172. 93 civic with DC2 headlights.
  173. SEARCHED hid question! helP!!
  174. 97 accord parts
  175. Rear running lights acting funny
  176. Aftermarket halogen bulbs
  177. brake lights wont turn off.
  178. Anyone else burning ballasts out on ebay kits?
  179. TYC projector, Depo clear fogs with HID X 2 installation for my EK with photos
  180. Replacement lens for foglights
  181. Integra Left side parking light not turning on. need help!
  182. Foglight Bulbs
  183. Headlights accord 1994 Sedan/saloon and coupe (european version)
  184. 98 Civic : H3 Xenon Headlight Install. Need Help!
  185. HIDs for custom headlights.
  186. HID dies every 5 minutes
  187. lumunics bulbs
  188. What to use as a shroud and bezel?
  189. Is this healight any good?
  190. Passenger side headlight wiring harness will not work
  191. putting neon light on civic
  192. jdm eg lights (city lights)
  193. Auto Relay for Jdm Fog Lights Needed
  194. HID H4H Recommendations
  195. anyone know what type of bulb are in yellow ek fogs?
  196. Ep3 Fog lights
  197. tail lights, cluster lights etc won't come on! please help!!!
  198. foglight question...
  199. gauge cluster question!!!
  200. 03 accord headlights
  201. 2008 Accord Coupe HID Question...
  202. how do i wire up a retro in my eg? supernoob 2 retros!
  203. passwordjdm fogs...
  204. seached and no answer: lighting.
  205. Bulbs Claiming to have HID/Xenon Quality
  206. Anybody think its possible to do a TSX light conversion on a EG? Just curious
  207. 2008 Accord Headlamp dimming issue
  208. headlight trouble
  209. 4th Gen Civic Headlight Questions...
  210. Removing 99-00 Civic headlights help?
  211. Prelude LED Dash Light Questions before I do it
  212. >-----> Halo lights on a Civic <---->For it or Agains it?? POLL
  213. Can you fit the 2004-2005 civic lights on a 2001 Civic???
  214. 2008 Accord 4 Door 4 cyl Fog Lights???
  215. Halo Projectors!!!
  216. Back lights on instrument cluster out, i need help please.
  217. removing clear lense from 99-00 ctr headlights
  218. a few ?'s on lights
  219. JDM Yellow frontend Fog Lights 88-91 Civic
  220. Which HID Kit is good
  221. Del Sol HID Issue
  222. lighting problem :(
  223. Were to find cheap jdm taillights or stock?
  224. help.
  225. Looking for some small/low profile, but bright driving lights for CRX
  226. Xenonworx® HID Systems
  227. O-NEX HID kit help
  228. sidemarker question
  229. Brightest bulbs for 92-95 civic headlights?
  230. PIC REQUEST: jdm front headlights harness set up
  231. light suggestions?
  232. HID kit, HIgh beams with H4 bulbs
  233. 92 accord headlight housing removal HELP!!!Meeeeeeeeee
  234. Anyone have experiences with these HID Kits:
  235. Headlights / Bulbs
  236. EG headlights
  237. weird bulb in my headlights
  238. oem>aftermarket
  239. oem>aftermarket
  240. NEED HELP WITH H3 BULBS!!!
  241. Anyone know these headlights?
  242. Foglight help
  243. silverstar turnsignals/parkinglights
  244. How do you install fog light on civic 94 ex
  245. superwhite bulbs for my amber corners?
  246. Eg hatch stock corner light socket
  247. Retrofit CTR housings?
  248. [FAQ] Lighting
  249. HID's for 2007 honda fit sport
  250. Hid Bulb
