PDA
View Full Version : Lighting
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13
  1. HID kit for non-hid JDM headlights on 95 Gsr ?
  2. OEM Style Civic Euro Headlights (black housing)
  3. Hi/Lo HID kit problems in 97 Civic (H4) Pls Help!
  4. Having a real hard time deciding!
  5. Converting single lamp to dual lamp headlight harness.
  6. how to clean my jdm eg headlights
  7. fog lights hooked to cruise controll switch
  8. Will HID kit in a brand new car void the warranty
  9. 2008 Honda Pilot and a HID kit.
  10. Can you adjust your stock head lights without taking the front bumber off??
  11. wiring fog lights.
  12. lo beam bulbs keep burning out of '02 Accord Coupe
  13. Help!! I need help replacing fog light bulb...
  14. Anybody with HID ?
  15. 98-01 oem hid fog conversion!!!...HELP!!!
  16. yellow rectangular fog lights, where can i find them
  17. diy h4 bi-xenon harness
  18. Help installing MTEC H4 HID kit on EG.
  19. How to clean headlights?
  20. How do I fix my Angel Eye?
  21. 90 ef hatch HID kit mounting
  22. High beams working, but low beams arent, help
  23. Changing bulbs question
  24. jdm sidemarkers
  25. H4 Bi Xenon HID Bulb HELP!
  26. how to adjust jdm integra hid headlights
  27. HID and DRL for 2008 Accord Coupe
  28. HID PnP kit but battery is in the trunk?
  29. ATT: denshu and retrofit pros, FX35 retrofit in eg
  30. accord parking lights not working
  31. Fog Light Wiring .... Help?
  32. Bulb replacement on a Phillips 4300k HID kit for Integra
  33. Buying jdm fogs 4 my 97hatch
  34. jdm rears (ek)
  35. How to wire H4 bulbs to 9006??
  36. What bulb
  37. wanna know if these are any good
  38. hid fogs
  39. Warning buying cheap HID kits on ebay.
  40. PROJECTION HEADLIGTS
  41. 92-95 civic coupe
  42. Need help whit tail lights
  43. Sidemarkers help
  44. 98 Teg D2S bulb question (Search disabled atm)
  45. What are the brightest trunk leds?
  46. Del Sol JDM headlight question?
  47. Whats the bluest bulb?
  48. Anyone have reviews of Xenith Xenons?
  49. ZBRA.com tail lights.
  50. EDM adjustable headlights. What do you need to get them working?
  51. NEW HELLA BULBS - DON'T BUY THEM
  52. head lights
  53. Side MArker Install Wiring help?
  54. s2000 headlights not working
  55. 06 Accord 4DR Fog Kit question.
  56. illumination wire?
  57. amber bulbs for gauge cluster
  58. new cluster faces... HELP!
  59. Where should I mount and how do I waterproof my ballast?!
  60. How much do those generic angel eye crx lights on ebay weight?
  61. DC2 conversion go chopped up, wondering on new wire harness
  62. hid problems
  63. Si vtec fogs for 96 teg help
  64. WTF is Up with this High/Low Kit?
  65. 48s LED light water proof
  66. How Do I Find Shortage to my Brake Lights!!!
  67. what HID kit to buy on EBAY?
  68. LEGAL LIMIT ON HID'S - NJ
  69. Motorcycle retrofit - which projector?
  70. 06 civic hid conversion question...
  71. Right turn signal too fast. 92 Civ
  72. HID bulbs are different color now....
  73. Need help on DIY headlight project for my dads DA9
  74. Bi-Xenon HID Kit?
  75. em1 fog light template
  76. hid question...
  77. license plates light doesnt turn on?
  78. 6000k HIDs....
  79. JDM HALF SWITCH (How to wire)
  80. dc2 oem hid custom shield to LHD Lots of pics !!!!56K beware!!!!!!!
  81. Ballasts Buzzing....
  82. projector headlight
  83. Help!! Lighting problem Turn my parking lights or headlights and rear left blinker doesnt blink and
  84. Hight and Low Beam Together
  85. Adjusting prelude lights?
  86. Help with HIDs :( (Who's right me or the eBay seller?)
  87. Help with H4 Connection
  88. Aiming OEM ITR HID's
  89. Only have Low Beams on HID Kit
  90. Looking to retrofit into my DA
  91. Step by step 92-95 Civic TSX retro-Fit in oem STYLE housing.
  92. dc2 jdm oem hid cut off pics
  93. Sylvania Silverstar Ultras 9003/H4
  94. help JDM front end
  95. Projector/HID
  96. FAST HELP!!!! WIRING ON EK FOGS
  97. Headlight Tinting?
  98. oven to do blackhousing??
  99. Quick question about HIDs
  100. help! guage cluster wont light up, cant see it at night !
  101. Projector retrofit and halogen bulb!?
  102. Driver's lowbeam doesn't work (HIDs)
  103. Fitment and Quality of these lights
  104. pic request: JDM front signal headlights
  105. Wiring gurus, dual electric fan setup.
  106. HID Question
  107. JDM lights yellow even after wetsand/polish
  108. using bondo to retrofit?
  109. HID on 2002 accord
  110. intersection lights template. L&R
  111. 99-00 Civic Ebay fog light switch and wiring.
  112. Does Voltage Stabilizers Work?
  113. Which HID to trust and buy?
  114. Is there a place that will retrofit your headlights for you?
  115. HID Bulbs on different ballasts
  116. HID Bulb replacement question
  117. eg clock light
  118. 00 si help retrofit what projecters to use?
  119. lights question
  120. The integra forum couldnt help me with this so.......
  121. HID INSTALL PLZ HELP
  122. 94-97 Accord Aftermarket 1peice head, retrofit/replace projector
  123. About to do a Bixenon retrofit
  124. Need help with wiring these hids
  125. Help with one piece headlights.
  126. HIDS / HID headlights only work in HIGH beam mode!?! Battery harness install.
  127. dome lights LED
  128. HID QUESTION
  129. Help!!! 96-98 Fog light install !!! need help/Instruction !!!
  130. EG Foglights question - Why is one side bright and the other not?
  131. Anyone know how to adjust the beam height of the following Headlights?
  132. 4th gen prelude retrofit??
  133. honda civic fog lights 96-98 OEM install (not round) help please!!!!!
  134. weird headlight problem
  135. is it ok to wire up oem stanley fogs to service lights?
  136. DIY: TSX Projector Retrofit into EF8/EF9 Headlights
  137. PICS REQUEST: EDM Rear Fog Light
  138. Not so "plug-n-play" xenith xenons
  139. LIGHTING PROBLEM
  140. anyone have OEM EG foglight kit installation directions?
  141. Plastic Headlight Restoration (Pics and Video!!!)
  142. 5th gen prelude hid install help
  143. Shroud Help
  144. HID help please
  145. Halo help on EJ1
  146. What is this part of my headlight and what does it do?
  147. Foglight Problem
  148. New Headlights Arrived.......Question!?!?
  149. projectors for 98 prelude?
  150. Headlight fuses keep blowing??..
  151. guage cluster needles don't light up
  152. ek tailight issue help. fuse keeps blowin.
  153. V-leds.com has anyone used them????
  154. Integra JDM headlight
  155. Fog Lights for 08 Civic?
  156. 880 bulb fog light to hid conversion
  157. Need help! searched!
  158. Hella Fogs HELP
  159. Brighter interior (gauge) lights?
  160. fog light question
  161. da 1 piece headlights different colors...
  162. Will a 9006 fit into a 9012
  163. Bulb equivalents?
  164. Question (?) on Installing 94-97 JDM SirG Fog Lights (HEEELP)
  165. bulbs from pepboyz
  166. 9012 bulb to 9006 conversion
  167. Sell: HID xenon kit
  168. EP3 Civic si 04 headlight adjust?? Please help...
  169. Tail light problem
  170. Dome Light doesn't turn on when I open my door. (1993 Prelude)
  171. Projectors
  172. Hid's with non-projector headlights?
  173. Anybody with HID in TYC projectors in an EK?
  174. 97 civic ex shoft light burned out and driving me crazy
  175. Just got Phillips 4300k HID - Doesn't power on/work
  176. HIDs not Working
  177. Best lighting option for a 92 civic short of an HID retrofit with OEM projectors?
  178. xentec hid conversion kit problem!!! NEED HELP!! :'(
  179. new blubs
  180. name that bulb...
  181. DEPO foglights
  182. h4h temporary replacement options
  183. HIDs + HID battery wire harness = Confused with wiring! *Quality pics* Please Help!!
  184. Ballast Help
  185. HID help
  186. What do you think?
  187. City lights on a 99-00 EK
  188. 10000k hids??
  189. Which bulb do I need?...
  190. dc2 HID lens
  191. hid dont work on my 99 civic
  192. Knight Rider Grille Lights... Are they legal?
  193. Halogens & HIDs
  194. TSX Projectors
  195. Anyone using a6 projectors?
  196. Sealing Ballast
  197. Retrofit 9006 to a Brighter Bulb
  198. Quick question
  199. how do u keep high and low beam on ???? on 93 hatch
  200. should i get HID highbeams?
  201. CTR HEADLIGHT Signal Socket
  202. cleaning the HID bulb
  203. hid help
  204. help on fog lights that can fit on a 4door civic 95
  205. Brightest 9006 out there.
  206. i want to meke my high beams amber can anybody help?
  207. tsx, ebay pnp, help
  208. Help me upgrade my lights!!
  209. bulbs that light the license plate?
  210. 99-00 FOG LIGHT QUESTION
  211. my reverse ligts on my crx 89' dont work
  212. What you use to seal you headlight
  213. eg sidemarkers problem.
  214. head light re-wire help....
  215. HID on older cars illegal?
  216. how do i re-wire my OEM foglights to turn on w/out my headlights being on in my 1991 integra?
  217. BIG!!!!!!!!! headlight problem
  218. Hi beam and low beam on
  219. interior lighting
  220. hid's
  221. anyone heard of sun auto?
  222. [How-To] Re-wire Your Foglights
  223. Let See Your Custom Rear Fogs!
  224. Lights (HID's) aren't turning on...
  225. autozone-pepboys fog's
  226. HID high beam hook up?
  227. Retro fitting civic ek headlights for hids
  228. what temp would you prefer?
  229. Shrouds necessary?
  230. OEM JDM DC2 HID Cutoff Question
  231. TSX and S2000, what oem brands for ballasts and bulbs?
  232. relay harness with HID setups
  233. Where can i get the 92-95 TYC HID Black RetroFit Headlights?
  234. 90 CRX si brake lights not work
  235. freshly made EG hid headlights
  236. Need feedback for suvlights.com harnesses
  237. Need feedback for suvlights.com harnesses
  238. H.I.Ds question....
  239. Brake Lights STAY ON.
  240. how do you install ebay eg fog lights
  241. Where can i get angel or deamon eyes for my Honda accord 96
  242. bd2 bumper lights not working?
  243. My teg has electrical problems....HELP ME ASAP
  244. 3 wires on 92-95 headlight harness. Which to use pnp HID kit?
  245. Which Would be Brighter?
  246. how do i make my blinkers flash faster?
  247. motorized HID setup?
  248. HID H4 Glare Shield
  249. will s2k ballast fit my jdm typer conversion ?
  250. HELPPPP!! HID / Fog Help
