Lighting HID/Xenon kits, Retrofits and Associated Topics
Fog Light Wiring
Old Sep 13, 2007 | 08:37 PM
goforbroke's Avatar
MEAT PATTY
Default Fog Light Wiring
I bought a ebay eg fog light kit not to long ago. The kit comes with stock 55 watt bulbs and they weren't bright enough more me so I upgraded to 100 watt bulbs and repeated to blow the 30 amp fuse. After reading up on this thread........
https://honda-tech.com/zerothread/1812043
It seems that the wiring supplied in the kit isn't thick enough to take the load of the drawl the bulbs are pulling. I'm curious has anyone else had this problem after they upgraded bulbs? I can't even see the kit being functional without upgrading the bulbs, seriously.
Old Sep 14, 2007 | 07:14 AM
goforbroke's Avatar
MEAT PATTY
Default Re: Fog Light Wiring (goforbroke)
anybody?
Old Sep 14, 2007 | 04:43 PM
goforbroke's Avatar
MEAT PATTY
Well I bought some 12 guage wire and I'm going to rewire the entire kit, which should be fun. The wire is rated at 288 watts and 24amps. So my two 100 watt bulbs should be fine. I'll let you guys know how it goes considering nobody has done this before?
Old Sep 14, 2007 | 06:48 PM
Padawan's Avatar
Darth ModerVader
I don't think that the wiring itself was responsible for your blown fuses, but upgrading it can't hurt, especially since stock wiring rarely provides full operating voltage to the lights. I would caution you against using 100 watt bulbs though, since they generate a considerable amount of heat, and even if they don't immediately melt your fog lamps, they will certainly cause accelerated deterioration of the plastic.
Old Sep 15, 2007 | 11:08 AM
goforbroke's Avatar
MEAT PATTY
Default Re: Fog Light Wiring (Padawan)
Thats a valid point I never thought about before. The heat generated by the bulbs, but for some reason I don't think its going to be a problem. I might take it into consideration though and coat the inside of the fog light housing.
Old Mar 23, 2008 | 03:11 PM
nudvl's Avatar
I had ebay EG style foglights on my eg without upgradin the bulbs but now I have 99/00 Civic Si foglights on my eg that keeps blowin fuses.
Solidis
Dec 12, 2013 08:08 PM
DCSportEJ1Civic
Feb 3, 2009 08:43 AM
Khmai_guy
Mar 10, 2005 09:57 PM
RedHackBatch
Jul 6, 2004 09:39 PM
rkn527
Nov 7, 2003 10:47 AM
