Lighting HID/Xenon kits, Retrofits and Associated Topics
New HID setup
Old Sep 26, 2007 | 12:57 PM
n8dizzel's Avatar
Default New HID setup
I installed my HID kit on my car and it had the direct plugin setup with no relay but i decided to go the correct way and run a relay and power from the battery. i have sever years as a stereo and car alarm installer so i know the wiring is done correctly. my only problem is that sometimes only one light will fire. if i turn the lights off and on again most of the time the second will fire and stay lit. has anyone else encountered this problem. i have heard even with pricey kits this can happen from time to time. if anyone watched that show bull-run that had happened to one of the guys and he had gotten pulled over for it.
Modified by n8dizzel at 2:10 PM 9/26/2007
Old Sep 26, 2007 | 01:21 PM
Padawan's Avatar
Darth ModerVader
Default Re: New HID setup (n8dizzel)
It's possible you have a bad ballast or ignitor, assuming your wiring work is correctly done.
Old Sep 26, 2007 | 01:24 PM
operatic's Avatar
Default Re: New HID setup (Padawan)
Take the bulb that is having troubles and put it on the other side (drivers to passenager side and vise-versa) and see if the problem follows the bulb. If it doesn't then it is the ballast.
Old Sep 26, 2007 | 02:35 PM
n8dizzel's Avatar
Default Re: New HID setup (operatic)
it happens in the left bulb damn near every time. and the bulb will flash but will not stay lit. im gunna go with the bulb being bad as it came with the kit and the whole thing shipped was only $80.
Old Sep 26, 2007 | 02:49 PM
Padawan's Avatar
Darth ModerVader
If you only paid $80 for your HID kit, I think that might be the answer to your question.
Old Sep 26, 2007 | 03:41 PM
n8dizzel's Avatar
I know I know you get what you pay for. just wanted to know if anyone else had this happen. i honestly think the transformer boxes are good and leaning more toward cheap bulbs.
UPDATE - since i know you were all waiting by your computers anxiously waiting to see what was the case with my HIDs. It turns out it was the bulb. I switched the bulb and wouldn't ya know now its the other side that does not want to fire. A quick phone call should get my a new one at no cost. We will see. When I Looked at the "bad" bulb i could see that the wires that went into the gas part of the bulb looked a little short in comparison to the "good" bulb which overall looked in better shape than the "bad" one. maybe just cheap bulbs with a semi-good kit perhaps. better than bad transformers.
Modified by n8dizzel at 6:12 PM 9/26/2007
Old Sep 30, 2007 | 09:16 PM
IT'S ME DAVID's Avatar
NooB
I has this problem.its the bulb.I changed the ignitor and ballast and nothing.finally changed the bulb and bang worked perfect ever since.
bestcivic
Lighting
Aug 14, 2009 12:16 AM
mookie86
Lighting
Mar 26, 2009 03:17 PM
DC2 Maggio
Honda Civic (2001 - 2005)
Feb 16, 2009 04:48 PM
EJ6_Sedan
19
Nov 21, 2007 10:21 PM
DrewDown
Mar 3, 2007 06:12 AM
