- headliht wireing
- What is this???
- fog light info????
- crx external lighting question
- What Ballasts to buy?
- questions about foglights
- OEM ballast re-wire nessecary?
- hid's for my supra
- retro solutions hid kit.. Questions.
- Wiring low beams and high beams to stay on at the same time.
- side marker issue
- can I retrofit any projector on a EG headlight
- same plugs for 96-98 & 99-00 foglights?
- Interior Lights
- Help with hids...only city lights work
- Ebay HID suck ass
- can any of you help me i have no low beams
- Ciciv CCFL angel eyes ballast issues! Help!
- IS300 fog retro pics
- **OFFICIAL** OEM EG / DC Sidemarker Template
- Turn signals blinking too quickly
- l.e.d./neon light interior
- Why do my tail lights and dashboard lights only go on when I brake?
- combining 96 n 00 fog light wires
- wing light stays on???
- recommendation for headlight restoration
- Amber Corner Lights
- 99 SiR Tail lights
- bad news regarding Toshiba HIR bulbs...
- how to install a basic H4 HID Kit for 96 CIVIC sedan
- Acura Integra fog Lights 94-97 Wiring Diagram
- power spoon mirros
- Fog light question..
- corner lights messed up
- Simple Relay Question (need answer asap)
- Dont want to lose high beams.
- Retrofit Complete
- Fog light hookup DIY help
- where do i buy hid replacement bulbs?
- Update on Denji housings w/ TSX projectors swapped w/ TSX-R Lens
- HID help
- K2 Motor Projection Headlights
- Best way to keep your headlights in good shape---
- help needed
- Whats the best HID kit?
- i need a 94 gsr headlight passenger side any1
- Retrofit w/ H1 Hi-beams, need help wiring
- Light Show
- need help with lights!! they won't turn on!!
- What are these called? And how to get some... *searched*
- HID xenon kits
- need help wiring rsx foglights
- H4 bulbs in HB2 SocketS?
- need help with gauge cluster lights
- CRX HID question
- Eg fog light help!
- EF Oem headlight housing with plastic cover
- HID Special $60 Shipped for Honda-Tech members
- HID light doesn't go on at the same time.
- 00 Civic led Halo projector headlights
- Front Page News -- Customlightz.com
- DIY Retro-Fit in 01-03 civic
- need help for hella fog lights instalation
- Headlight question 00 si
- Recommended retrofitter
- HID bulb size for eg fog ????
- Need help wiring S2000 front signal lights to 93 Hatch
- Help wiring city lights
- Drive Side OEM HID blinks then cuts out?JDM OEM INTEGRA
- how to retrofit 00 ek lights
- break light help
- 95 integra high beam HELP!!
- Best place to buy retrofitted headlights?
- Retrofitting Denjis
- HID Retrofit in my EJ8!
- 94-97 integra fog light wiring. help
- Retro Question (94-97 Accord)
- de-rice me please!
- LED light in trunk
- How to find a shortage?
- Question regarding PnP to retro on 6th gen civic
- New gauges and tail LEDS
- TSX or FX projectors?
- HID headlights
- Making Custom tailight leds
- Turn Signal Flasher Box Help
- Clearing Projector Lenses
- turn signals/brake lights, need diagram...
- Headlights/Tail lights.
- The truth about HID kits
- My dim lights
- Fog Light Wiring Help. OEM Switch to Aftermarket
- 96-98 fog light wiring harness
- Links to HID Planet forum threads ARE NOW allowed
- Where to find Civic 96-00 oem fog lights
- 01' Accord Turn signal
- 6K or 8k PnP HID kit
- What hid kit?
- My Retrofit =)
- HID ballast (not working)
- problem with aiming 98 civic headlights.
- retrofitting a 5th gen prelude
- no reverse lights....90 ef
- Cops and HID lights
- Yellowing on my CTR headlights.. How to fix?
- Highbeams/DRL's
- For those if you with yellow fogs...
- If you want OEM fogs, check this out!!!!
- small bixenon projector kits any good?
- need hid advise
- Electric problem. please help ASAP =(
- How to prevent yellowing of headlights...
- help with civic climate control lights?
- hids in generic fogs
- 92-95 civic light wiring question
- WHICH PRODUCT ?? ... To seal headlights back up.
- Wiring up side markers
- Removing headlight glue and silicone
- Glow Gauges
- Intercooler piping VS. 99 00 civic foglights
- Help with HID kit for 05 accord
- Retrofitting JDM DC Headlights
- 91 prelude
- 99 00 Civic retro fit question
- Proper alignment
- Please help (Retrofit in USDM EF headlights)
- DIY JDM STYLE headlight....WRITE-UP
- looking for yellow transparent headlight paint
- halos NEED HELP!!
- Hid help
- 99-00 Foglight Help
- HID's
- 99-00 Depo Fog light help! Blowing Fuses!!!!
- turn signal (blinker)
- tail light problem
- DIY blacking out housings
- HID Wiring question
- Password:JDM DC2 '94-'01 Integra Type-R Headlight Jumper Harness ?
- '95 Civic Gauges LED Makeover - How Many?
- H3 bulb in H1 housing
- water in headlights ?!
- Can't find!!
- rsx cluster and climate control,not lighting up..help
- spliting corner lights.
- HID in 2008 Accord
- 07 Land Rover HID's in DC2?
- DC2 HID retrofit parts list
- Light Bulbs?
- acura legend
- 03 Civic Headlamp Assy replcmt
- ok so no PNP hidkits 4 the HT guys.WAT DO YOU RECCOMEND I GET?CRAIGSLIST?
- Cleaning headlights?
- Help my fog lights don't work
- instrument/guage lights dont work anymore!!
- FOG LiGHTS DON'T WORK.
- Looking for Interior Lightbulbs
- Wiring pnp eBay hid kit to use as hi beams in a retro
- will my HID's work for a jdm front end conversion?
- Would Ls430 Projectors fit into a DC2 headlight?
- 98+ OEM Integra Fog Lights... HELP!!!
- Help My running lights don't work anymore.
- need help opening headlights...
- 9004 to H4 conversion
- HID in fogs
- Bixenon Wiring?
- On fire twice( what is going ON)
- silly projector question...?
- HID questions/options?
- HID questions for 4th gen prelude.
- 95 honda civic dx headlights
- Best 'bang for the buck' headlight bulbs?
- retrofit writeup??
- 96-98 ek fog lights
- Cluster LED question????
- will they work h4 in jdm eg
- HID problem...
- Del Sol JDM fog light bulbs???
- Anything else fit into 1157?
- 12000k HID fine in stock headlight?
- Please post pics of Retrofits in EK
- For those looking for Denji Headlights
- HID Installation- 01 Accord
- Fog light problem
- Stock headlights or HIDs without projectors
- Bulbs burnt out any suggestion on upgrades? HID Kit?
- whats the diffrence? diamond/ regualr
- Wiring and cost
- JDM Yellow Head Lights, Corners and Bumper lights
- retrofit projector
- Bulb Question: Does P21W fit in 1156 sockets?
- fog lights with ic piping
- Brake lights dont work HELP ME
- Need help with Depo and HID's.
- hids
- Where can I get these?
- H4 or 9003 for EM1?
- 194A bulbs
- City lights for 98-01 Integra headlight?
- Blue HeadLights
- h.i.d.s
- Anyone have or had PIAA headlight bulbs?
- Brake Lights don't turn on please help
- Best brands of aftermarket bright bulbs
- Retro Integra
- Adjusting 99-00 headlights
- HID Kit question
- HID KITS for 1994 accord?
- ► Humbly requesting your support...
- retrofit in ebay headlights
- Projector or jdm
- Bright yellow bulbs for OEM 00 Fogs
- Question on Type-R Fog Light switch
- Retro's question
- Need some help with relay install for fogs (H11)
- HID fogs?
- headlight wireing for a 96 hatch
- HID install / Aftermarket Projectors
- HID issues
- How to wire up Denjis on EG..??
- Honda Civic 98 Fogs
- HID'S only working on Hgh Beam
- instrument panel bulbs
- em1 head light with city light
- Wanted ef retrofit pics
- Fog lights!!!driving me nuts!!!
- DIY Eg fog light instructions
- dash lights wont work
- need help with e55 bi-xenon retro into DC
- Raybrig or Depo Fogs
- is this a bad bulb??
- Brighest Headlight bulb
- Neep opinions on led selection blue gauges
- HID kit for Civic Hatch 93 eg
- Retrofit parts
- Best hid kit
- PIC request HID retro in a DA
- Left Low beam doesn't work but high beam does
- H11 bulbs & 9006 ballasts
- ONEX Hid kits?
- 93 eg
- headlamp cleaning (plastic)
- LED cluster doesn't work - bypass dimmer?
- park, tail, and dash lights are not working on Fifth gen prelude
- Ek fog light measurements
- JDM front lamp SAE/DOT approval problem
- Turn signal side mirrors for 09 Fit?
- 93 Civic EX Blinkers and Cluster not working...
- Help cleaning jdm ctr headlights
- What brand fog lights are you using
- Fog lights
